Will a 305/70/16 fit on my F250?
Well according to the website, they should fit. They measure in at 32.68". But the issue will "might" have is the rim. They recommend an 8" thru 9.5" rim with that tire. Preferred 9" rim.
I am thinking that the OEM SD rim is 8", but it might only be 7". I cannot remember off hand. Maybe someone will chime in here...and give a positive answer.
But for the height issue...no problem. The width issue...might rub. I had the LT285/75R16 tires on my SD at one time. No rub at all. They were at 32.76" in height. Just not as wide.
biz
_____________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
biz
Originally Posted by captkrunch
I don't know if this helps you but I have a 2006 with 305/65/17's with no rub at all
biz
[QUOTE=LXguy]Hey All:
I have an unlifted 2003 F250 V10. I'm looking at the 305/70/16 Terra grapplers. Will they fit on my truck?
Thanks!
YES
I had 305/70R16 Nittos on my 4x4 F-350 with no rubbing issues
my buddy with a older F-250 2wd just put them on and they actually fit his
I just went up to a 315/70R17 BFG AT and they look and fit great!
Thanks!
YES
Here's pics of 305's on my '04 before the lift.
Minor rubbing under full lock and a hard bump. Just on the plstic fender liner though.
https://www.ford-trucks.com/user_gal...oid=66392&.jpg
https://www.ford-trucks.com/user_gal...oid=83896&.jpg
https://www.ford-trucks.com/user_gal...oid=66390&.jpg
