Gas tank for Highboy
Old 06-15-2006, 11:14 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
I have done a search on this forum and I haven't found really any clear cut answers about a tank for the rear of a 77 ford F250 highboy. I do know that highboys had the in cab tank which I want to get rid of and place one behind the rear axle. There are different answers to if the 33 gal tank out of a bronco works. Does a bronco tank fit between the frame? Also, I checked out aerotanks.com. Does the 32 gal aux tank for 70-85 trucks part # 1028 work? Has anyone put that in their vehicle? What was the cost?
Old 06-16-2006, 04:50 AM
hogworkzinc's Avatar
hogworkzinc
hogworkzinc is offline
Dentside-aholic Supporter
I put the 33 gal Bronco tank under my 76 F100 4x4. It fit between the frame okay, but I am assuming the frames are the same width. I ran some all thread through some square tubing and used big washers to connect the top straps to the skid pan and through the cross members to hold it on. The only real problem is that the overflow neck is to the rear of the filler neck on the tank. It is on the foward side at the gas cap. I just moved it to the rear at the gas cap. I got the tank, skidpan, straps, lockring and sending unit that go with the 33 gal tank from Jeff's Bronco Graveyard. I don't remeber the price. I'll check when I get home on Monday.
Old 06-16-2006, 10:38 AM
Madmike33's Avatar
Madmike33
Madmike33 is offline
Well I'm looking at putting a tank in the back of my Highboy also. I've read a lot of threads on this in the past, and trust me... ford hasn't made it easy for us highboy owners to pull the tank out of the cab and put one behind the rear axle. The highboy has a more narrow frame than any other ford truck of those years.... So two choices are left to us.
1. Find a camper special rear tank (good luck)
2. Get creative, have one made, find any other tank that'll fit the measurements of your frame.
I'm using a Bronco 2, 23 gallon fuel tank (early 80s... ex: 84), Oh and I found a plastic tank from JBG.
Good luck
Madmike33
Old 06-16-2006, 11:34 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
FordTrucksKickGM is offline
There have been lots of threads on this topic. There are no simple swaps. You have to be creative if you want a rear tank. Your best bet is to measure the area you want to put the tank in then go to the junkyard and look for something that will fit such as a BroncoII as noted above. Heres a tip: You wont find a tank from a 73-79 Ford truck that will fit.
Old 06-16-2006, 12:08 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Apparently the Fuel Tank from an Old Mustang/Maverick/Comet will fit in between the frame on Highboys.
Old 06-16-2006, 12:29 PM
fordraceboy's Avatar
fordraceboy
fordraceboy is offline
the bronco II is a good fit, i'd look at jeeps also, they're all rear tanks, but i think they're only 20 gallons if thats an issue...
Old 06-16-2006, 12:38 PM
btacarlton's Avatar
btacarlton
btacarlton is offline
There is thread on here somewhere about using a 73-79 rear mounted tank and turning it sideways. I did that to my 77 F250 Highboy and it seems to work pretty good.
Old 06-16-2006, 12:52 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
I always wondered if a tank from a Chevy/GMC Suburban, Blazer, Jimmy would fit. The GM truck frames tended to be narrower than Ford truck frames.
Old 06-16-2006, 03:36 PM
Madmike33's Avatar
Madmike33
What I did was take the measurements insisde the frame then I went to gas tank online sites, and started looking through their inventory. Gas tank dimensions are listed and then all you have to do is decide if you look for a used one or by one new.
Madmike33
Old 06-16-2006, 04:09 PM
bucks77ford
Thanks for the ideas. My initial idea was to just make my own tank out of some diamond plated steel, but I thought if I could get an actual fuel tank that would fit nicely without a whole lot fabrication than I would do that. I would really hate to spend over 200 bucks for a fuel tank, but if that's what it is going to take, than I guess that' what I'll have to do.
Old 06-17-2006, 02:56 PM
goldnickle's Avatar
goldnickle
goldnickle is offline
I turned a 19 gal. stock tank sideways, but now I'm looking at a full size '78-'79 bronco 25.5 gal, tank it measures 21"x31"x12", I have mine mounted just in front of the rear axle
Old 06-18-2006, 12:38 AM
fordraceboy
suburban tanks also go in without too much trouble, and they're 40 gallons..
PhilMac
16
12-06-2020 08:48 PM
Zazoos
100
11-24-2019 11:45 PM
supermanbidder
09-01-2015 07:41 PM
Willisp33
06-23-2011 12:46 PM
bucks77ford
04-25-2008 10:48 AM
Quick Reply: Gas tank for Highboy
