leaking oil filter canister
Old 06-09-2006, 12:09 PM
John - NNY's Avatar
John - NNY
John - NNY is offline
I have a 1948 337 ci flathead in my F-7 truck. The original filter canister was leaking. It was replaced with another used filter canister. This one is leaking also. The top cover seal is not leaking. The leak is somewhere on the bottom. The leak could be comming from the lines, drain plug, or crack somewhere.
Is this a common problem on the old flathead filter cans???
John
NNY
Old 06-10-2006, 12:26 PM
kotzy's Avatar
kotzy
kotzy is offline
your using the same lines/fittings, are you sure you don't have a cracked fitting or line? Those canisters are preety heavy. If you do find a problem in the can a good guy with a torch can braze or weld it.
John - NNY
27
01-17-2015 06:31 PM
John - NNY
24
03-20-2007 04:29 PM
John - NNY
Flathead V8 & Flathead 6
04-26-2006 08:55 AM
John - NNY
04-03-2006 09:49 AM
John Ezell
25
05-23-2004 02:00 AM
Quick Reply: leaking oil filter canister
