1983 Bronco variable venturi carb replacement
Old 06-08-2006, 05:39 PM
AzCoder's Avatar
AzCoder
AzCoder is offline
Question 1983 Bronco variable venturi carb replacement
I have a 1983 big bronco with a 351w engine. I want to replace the worn out variable venturi carb with a new 2 or 4 barrel carb. What is the best way to go? This is a stock engine with auromatic and is used mostly to 4-wheel and camp. Should I use something like an Edelbrock intake manifold with a 4 barrel carburetor? If so, what models? I also do not have to get emissions tests if it makes a difference.
Old 06-08-2006, 08:02 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,661 Likes on 1,343 Posts
Get an edelbrock performer intake with a 500 or 600 cfm edelbrock carb. You will have a choice of manual or automatic electric choke, and make sure you get the kit for the ford automatic kickdown linkage. They may have a carb model with the ford kickdown linkage already installed(Holley does). www.jegs.com has a good selection.
Old 06-09-2006, 05:49 PM
baddad457's Avatar
baddad457
baddad457 is offline
A cheaper route would be a Holley 350 cfm 2 bbl. Should be a bolt on swap, only a minor reroute of the fuel line to fit your 351.
Old 06-10-2006, 10:16 AM
AzCoder's Avatar
AzCoder
AzCoder is offline
Is there any problem with the EGR stuff? Do I leave all this stuff in place or do you rip it out? Would I have to get the EGR version of the Edelbrock manifold? For the 2 bbl solution, what model Holly carb would it be?
Old 06-10-2006, 02:53 PM
BroncoRoadKill's Avatar
BroncoRoadKill
BroncoRoadKill is offline
The holley 2300 series carb is the 2 barrel and you can get it with or without electric choke.
I would use the stock venturi carb before an edelcrap carb any day of the week.
They don't even make a very good boat anchor, the pot metal that there made out of is too light.
Old 06-11-2006, 12:07 PM
AzCoder's Avatar
AzCoder
AzCoder is offline
So what version of the Holley 2300 would be the best for my stock Bronco? Would it be the #O-7448 (350 CFM) for $249.99 or the #O-4412C (500 CFM) for $229.99? Is the 500 CFM model too big?
Old 06-12-2006, 01:42 AM
BroncoRoadKill
I would say the 500 cause I have a 580 street avenger and it works lik a top.
Old 06-12-2006, 09:15 AM
baddad457's Avatar
baddad457
If all you're doing with the truck is going to the camp and never use the motor to it's full potential, and are't planning on upgrades to the engine, the List # 7448 350 cfm will do fine. If you want more out of the motor then go with the 500.
Old 06-27-2006, 11:04 PM
AzCoder's Avatar
AzCoder
AzCoder is offline
OK, I got the 4412C (500CFM) with electric choke. What do I need to do to install this thing? What stuff do I need to block off or tear out to make it work? Any help would be appreciated.
Old 06-28-2006, 09:13 AM
baddad457's Avatar
baddad457
I'm not there to see what you're doing , but for the EGR, if it's a separate spacer under the carb with a diaphram switch, remove the switch from the spacer and make a steel cover to replace it. Then just bolt the carb in place of the old one. You'll figure out the rest as far as the fuel line, vacuum hoses and linkage. Just remember to install an inline fuel filter between the carb and fuel pump. Follow the instructions for the choke that're included with the carb. I can't tell you how that hooks up, I never use the things.
Old 07-10-2006, 10:52 PM
AzCoder's Avatar
AzCoder
AzCoder is offline
The old vv-7200 has a throttle position sensor that connects to the wiring harness. What do I do with this connection? There is also another electical connection on the front right. Can I ignore these? I think the distributor needs this information????
Jim
Old 07-15-2006, 07:26 PM
johnraym's Avatar
johnraym
johnraym is offline
7200vv
When I got rid of mine I replaced the distributor with a duraspark II. Also an ignition module. At this point your computer is out of the loop and will no longer be able to control egr,AIR, mixture or timing. In short you can remove it and the harness that comes from the computer.
Old 07-18-2006, 09:56 AM
AzCoder's Avatar
AzCoder
AzCoder is offline
johnraym said "When I got rid of mine I replaced the distributor with a duraspark II. Also an ignition module."
What year and model 351 did you get the distributor/module from? Do I need to change to the duraspark II or can I leave things like they are now?
Old 07-18-2006, 12:42 PM
johnraym's Avatar
johnraym
johnraym is offline
7200vv
If I remember right it was from a 77/78 . I just had the parts guy search on engine, It was a single vacuum advance. I believe the module was "blue" grommet.
PeeWee525
05-26-2017 12:32 PM
datler
04-10-2012 10:01 AM
Warhawk
08-09-2003 07:21 PM
ltd91_351
11-24-2002 12:27 AM
Bull
17
01-31-2002 09:38 PM
Quick Reply: 1983 Bronco variable venturi carb replacement
