Fuel leak on top of engine
Old 06-01-2006, 04:34 PM
pioneer's Avatar
pioneer
pioneer is offline
I have a 97 super duty with a powerstroke. I have a fuel leak on top of the engine and I can not locate where it is coming from. Any help?
Old 06-01-2006, 04:47 PM
the weez's Avatar
the weez
the weez is offline
I'm no expert by a long shot but I had the same problem and question a few days(post's) ago. Scroll down a bit and check it out. Your truck is the same age as mine, I have 122k on the motor, so without anymore info, I would guess your fuel pump is going to be the problem. There's a little weep hole at the bottom of the pump that was shooting out fuel on mine. It was hard to see at first and wasn't noticable when the truck was idling in the driveway, I had to steam the motor then take it for a drive on the freeway to check the results.
Old 06-01-2006, 06:01 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome Pioneer to Ford Truck Enthusiasts!
See you on the boards. ….
Old 06-01-2006, 07:47 PM
hjfmtex's Avatar
hjfmtex
hjfmtex is offline
I had a leak on top of mine too. I found that a vacuum switch off the driverside of the fuel filter housing was leaking. Seems like the little jewel was about $45.00 at the dealership. If I remember right, I could not get it at a parts store.
Now, I have another leak off the back side of the filter housing that I cannot see. I am afraid I am going to have to pull off some of the Turbo to find it. If anyone has an idea of what i can look for, I would appreciate it.
97 F250 7.3L PS Crew Cab 4x4
Old 06-01-2006, 08:05 PM
hjfmtex's Avatar
hjfmtex
hjfmtex is offline
Just went digging in the Forums a little more. Evidently, it can be the fuel pump leaking or hoses. Guess I am fixing to get my hands dirty. Go to some of the past postings and check it out...
Old 06-06-2006, 11:31 PM
timmosazz's Avatar
timmosazz
timmosazz is offline
I just had the same problem. I started to change the fuel pump and what a pain. The darn thing is burried by the turbo. Took it to a mechanic and he couldn't convince either of us it was the fuel pump. So we changed everything unde the turbo. I can give you a list of the parts if you need them. It cost me $1300.00 but it is all undre warrinty and we shouldnt have to go back in. And it was worth the money its a big job.
1997 F250 PSD 4WD 153000 Mi.
Old 06-07-2006, 12:32 AM
14psd's Avatar
14psd
14psd is offline
If it is your fuel pump I did mine and I'm not the most mechanically inclined but it did take me most of the day about 7 hours. It is kinda a biznach to get too but I did not have to remove the turbo, a lot of stuff around it but not the turbo. Oh by the way if you do decide to tackle it yourself be sure and keep your head on strait and not get worked up. Yes you will become VERY familiar with your truck almost personal with it.
Old 06-07-2006, 09:18 PM
BLACK F 350's Avatar
BLACK F 350
BLACK F 350 is offline
Smile
i hade the same probleme solved over the week-end was the pump
tanks folks
Old 06-09-2006, 09:02 AM
timmosazz's Avatar
timmosazz
one more thing. My truck was built for California. And I have been told that the exaust system, basically the turbo makes this job tougher. I hope your truck isn't a California truck. I don't know this for fact but I rember hearing this. Good luck.
Old 06-09-2006, 12:24 PM
timmosazz's Avatar
timmosazz
Also rember to be real carefull when pulling out the old fuel pump, I have heard of the plunger on the bottom of the fuel pump falling into the engine, use nedle nose plyers to grab it as soon as possable.
Old 06-09-2006, 03:30 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
I stole this from a really great website on our trucks.
Thanks to "Steve Baz".
On California-emission vehicles the banjo fitting is too far under the turbo and fuel line damper to reach with a wrench and access is restricted for using a socket (you may get the bolt out, but good luck getting the it back in). In this case and with the Econoline due to its body design, it is necessary to remove the turbocharger to remove the lift pump instead of the fuel filter housing. In all cases, when installing the new lift pump, lube the o-ring on the pump shank with dielectric grease and start the banjo bolt a couple of threads before installing a tightening the mounting bolts. Again, take care not to damage the sealing washers. Once the pump is secured to the block, tighten the banjo bolt to 40 ft/lbs.
Old 06-11-2006, 02:06 PM
cap's Avatar
cap
cap is offline
I see that nobody mentioned the possibility of a leaking Fuel filter housing. I'm finding out that this is a major problem on our PSD's. (94 to 97). They seem to leak at the bottom between the mounting feet, either a long crack or a pin hole.
Old 06-11-2006, 02:12 PM
1997F-350's Avatar
1997F-350
1997F-350 is offline
that can be repaired by jb weld if it is the housing.
ca truck are harder due to removing the turbo.
but this job can be done by yourself for around 150 bucks. a little more for a ca truck due to orings and such for the pedistal.
to keep the tappet from falling in the oil pan. once fuel pump is loose and blue hoses are disconnected turn the crank by hand with a 24mm socket and ratchet. this will unseat the fuel pump and lift it up about an inch. once its up just pull it straight out and you should be fine.
Old 06-11-2006, 04:28 PM
BigRed350's Avatar
BigRed350
BigRed350 is offline
Had this problem last year, the valley under the pump would fill up with fuel and ten run down the back of the engine, appearing to be leaking from the t/c cover. I took it to the shop, the mechanic took a small dentists mirror (availabe at Walgreen's for under 5 bucks!) and held it down in the valley looking up at the bottom of the pump with the engine running. Sure enough, just like The Weez said, there was fuel exiting the bleed hole on the pump. He replaced it with a Motorcraft stock pump, as well as all hoses. Parts and labor was 300 dollars.
Old 06-15-2006, 09:24 AM
J Lnance's Avatar
J Lnance
J Lnance is offline
Wink F350/hips
White 1997 F350 Crue Cab Dually. 7.3 Powerstroke, 180,000 miles. Popup gooseneck 21L conversion package. Standard fuel tanks + 90 gal in the bed with separate fuel pump. Overhead console with built in strobe lights, aircraft directional reading lights and built in CB mount. Cab trimmed in solid walnut.
Love my truck!!!
F350/hips
Quick Reply: Fuel leak on top of engine
