certain brands get better mileage?
Old 05-25-2006, 09:46 PM
bbf150's Avatar
bbf150
bbf150 is offline
i've owned this truck for almost 2 yrs and put 25,000 miles on it-'77 f150 2wd 400 performer intake,holley 600dp carb,c-6 with 2.75 gear-usually run marathon and shell gas but filled up with sunoco and mileage is never over 12mpg no matter what-well got 14.4mpg around town,couldn't believe it-anyone else ever experience this
Old 05-25-2006, 10:29 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
It can happen. Keep using the Sunoco!
Old 05-26-2006, 10:57 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
I may have less ethanol in it than the other brands. Here in CA, brand makes absolutely no difference because the formula is so highly regulated.
Jim
Old 06-04-2006, 01:50 AM
bigjohn1985's Avatar
bigjohn1985
bigjohn1985 is offline
there s somthing the gas companeys are hiding from you and me
1ethanol helps mpg
2 unless u live in the city u may not be getting the brand u want or think ur getting
3 if u get gas when there filling there tanks u get the dirt from the bottomof there tanks
4 and they use water to daloot the gas
Old 06-04-2006, 05:18 AM
aurgathor's Avatar
aurgathor
aurgathor is offline
1 ethanol helps mpg
Nope. Ethanol is there to help with emission. If anything, it will slightly decrease mpg since it has less energy than gasoline.
Assuming "daloot" neans 'dilute', this is utter non-sense.
Old 06-04-2006, 08:59 AM
99F150's Avatar
99F150
99F150 is offline
I think what he means in #4 is the gas is separated in the pipeline between loads by water. The pipe line must pump a certain amount of the fuel at the end of a load and the beginning of the next load into what is called a slush tank. This fuel contains the water that separated the loads.
Un branded stations and station owners that are crooks by this fuel from the slush tank and a cheaper price and sell it. This fuel also lacks all aditives that the name brand station would add at the bulk plant before taking it to the station.
I personally always buy my gas from a reputable name brand station to avoid getting this slush tank gas. I get the best mpg from BP Amoco in my Fords.
Dan
Old 06-04-2006, 02:43 PM
aurgathor's Avatar
aurgathor
Gasoline and water doesn't mix, so if you mix them, they'll separate. Alas, this isn't fully true for blends with ethanol, but it's still not something you can just mix with water.
Old 06-04-2006, 03:56 PM
99F150's Avatar
99F150
99F150 is offline
Not sure if we are on the same page?
They do not mix water with the gas. The water is in the same holding (Slush)tank as the gas and that gets pumped into your gas tank. Not good, and yes ethanol will absorb water.
93XR7
121
03-09-2009 03:20 PM
QwkTrip
17
12-24-2008 08:37 AM
jodeben
2004 - 2008 F150
03-15-2008 07:25 AM
Kijutsu
1983 - 2012 Ranger & B-Series
11-09-2007 09:09 AM
gomsu
09-02-2004 11:53 AM
Quick Reply: certain brands get better mileage?
