Adding cruise control to a 2005 F150 4.2L
Old 05-19-2006, 08:58 AM
jamieay's Avatar
jamieay
jamieay is offline
Hello! I'm trying to figure out how / if cruise control can be added to a 2005 F150 with the 4.2L V6. I bought an aftermarket kit, popped the hood, and then learned all about electronic throttles . What (aside from adding the cruise control switches) do you have to do?
Thanks!
Jamie
Old 05-19-2006, 04:04 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 05-22-2006, 09:29 PM
xtrm1stang's Avatar
xtrm1stang
xtrm1stang is offline
it's easy, but the kit from the dealer, and have it installed there, it is a new steering wheel wiht cruise switches in it, and then teh dealer must reprogram the pcm and turn on the cruise control function, that's it, dont know the price of the kit, but should be 1 hour to install
Old 05-22-2006, 09:32 PM
jamieay's Avatar
jamieay
jamieay is offline
Cruise Control
Thanks for the info! Do you have (or can you get) a part number for the kit?
Thanks!
Jamie
Old 05-23-2006, 07:45 AM
orgnova's Avatar
orgnova
orgnova is offline
sometimes you can find a steering wheel with cruise on ebay alot cheaper than the dealer. the dealer will charge about $50 to turn it on. its pretty easy to do yourself.
Old 05-23-2006, 08:00 AM
jamieay's Avatar
jamieay
jamieay is offline
Cruise Control
Unfortunately my local dealer seemed somewhere between clueless and uninterested. Maybe I'll see if I can get a wheel off of eBay like it was suggested and talk to another dealer about reflashing the PCM. Has anyone here had this done (or done it if you're a tech)?
Thanks again!
Jamie
Old 05-23-2006, 10:06 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
Jamie,
I had purchased my steering wheel for about 100bux, (98.xx) from a dealership in the next state over (NC) and went back home to Greenville and had my dealership put it on. This was also a clueless thing for them too. But after careful coaxing and the potential that I'd bring'em return buisness for similar things, I talked them into it. They figured if their techs knew how to replace one for (any) reason they should know how to put on in for the first time. I did remind them however that it would have to be turned on in the pcm/ecm (they prolly knew already). So right less than 70bux and a hr later, out comes my truck with cruise control. Final cost ...approx. 169$ including a brand new steering wheel. I would have attempted it myself, but I was home on vacation- and wanted to keep my wrench turning to a minimum.
Old 05-23-2006, 10:16 PM
FTE Trigger
I forgot to mention,
I think I have the p/n scribbled down somewhere...if not, I believe there was a few lenghty threads on the (by searching) "Adding cruise" topic...maybe you can catch the p/n there too...
Old 05-23-2006, 10:28 PM
xtrm1stang's Avatar
xtrm1stang
may be tricky trying yourself, remember your messing with the air bags, and I have seen them deploy while the veh was in a shop and the tech didn't follow the instructions correctly
Old 05-29-2006, 12:41 PM
aerio's Avatar
aerio
aerio is offline
PLS post P/N #
Old 05-29-2006, 07:04 PM
FTE Trigger
Lightbulb
Originally Posted by aerio
PLS post P/N #
http://www.fordaccessoriesstore.com/fas/b2c/catalog.asp
Black Speed Control
Part Number: 4L3Z-9A818-AAA
MSRP: $165.93
Note!: I didn't pay nearly that much by purchasing it locally from a dealer. (Dale Jarrett Ford) The dealer had 4-5 on the shelf- everyone else would have had to order it. The 165. is pretty close to what I paid for the kit and install together. I purchased it at Dale Jarrett and had my Local dealer (Fairway Ford) do the swap.
Old 05-30-2006, 09:45 AM
aerio's Avatar
aerio
aerio is offline
Thank You for the P/N # do you have a # for Dale jerrit thanks
Old 05-30-2006, 06:25 PM
FTE Trigger
Lightbulb Web addy and contact info....
... do you have a # for Dale jerrit thanks
http://www.dalejarrettford.com/Department-Parts.aspx <-web address
Phone: 704-283-0616
Fax: 704-225-1671
Email: ()
Old 12-15-2012, 02:57 PM
hhott71's Avatar
hhott71
hhott71 is offline
I see y'all are clueless as the ford dealer about installing cruise control on the 2004 to 2008 F150.
www.bought4less.com sells the cruise control kit for $120. It must have the ECM flashed.
Great thing is it looks and operates like factory.
Old 12-15-2012, 03:01 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Clueless?
I dunno, maybe this module wasn't available way back in '06 when this thread was first posted. And '07's and '08's weren't even being made yet.
Stewart
Quick Reply: Adding cruise control to a 2005 F150 4.2L
