63 ford ranchero
Old 05-15-2006, 06:34 PM
ENDEL clothing's Avatar
ENDEL clothing
ENDEL clothing is offline
Question 63 ford ranchero
I need some advice. I am wondering if there is a frame kit that I have to buy to drop a 5.0 EFI motor into my 63 ranch. Also if you have any tips/tricks to get me going on restoring my 63 please let me know. Thanks.
Old 05-17-2006, 05:58 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 05-17-2006, 05:32 PM
bertha66's Avatar
bertha66
bertha66 is offline
I have seen the Falcon Rancheros with the 289 engines in them, not sure if they were a bolt in deal. But if the 289 would go in I'm sure that the 5.0 will go in. Dearborn Classics has a lot of good parts for the Rancheros.
Old 05-26-2006, 03:46 PM
Roger Carter's Avatar
Roger Carter
Roger Carter is offline
The 260 V8 was a factory option in 1963. The 5.0 is a derivation of the 260. Using 1963-1965 Falcon frame mounts and insulators will let you bolt the 5.0 into the 63 Ranchero. Trans mounts aren't quite as clear. The trans you use will dictate which mount you go with. The Falcons had a cantilevered spring mount, unlike other Fords. As the previous post indicated, Dearborn Classics, as well as other Falcon vencors, should have the pieces to complete the install.
Good luck
Roger Carter
johnnychrome777
1961 - 1963 F100 Unibody
09-06-2012 11:47 AM
63F100
Paint & Bodywork
05-20-2002 08:52 PM
63 diehard
12-04-2001 11:31 PM
63 diehard
12-04-2001 11:31 PM
Quick Reply: 63 ford ranchero
