B20 on the IDI
on
1 Post
B20 on the IDI
What has the experience been on running B20 on the older 6.9l and 7.3l diesels with the IDI engines (1994 and older)?
Has anybody had there Stanadyne IP pack it in due to problems with natural rubber o-rings?
Any other things to watch for (other than the fuel filter changes) during intitial conversion?
Originally Posted by cookie88
Hmmm...no action in the IDI forum. Lets slide this one down to the BioD forums and see if we can get you an answer.
FABMANDELUX.
I've got a 1992 idi which I have run many tanks of bio diesel in the last 14 months. just change your fuel filter soon after switching. as for the natural rubber lines, they should be ok as long as there is no considerable seepage so that the stuff gets on the out side and eats away at it. I use either B 50 or less made out of waste vegetable oil. If you can get stuff made out of soy oil, that would make it burn better. if your idi is not turbo'd, it will not burn the bio diesel as good cuz it takes more oxygen and boost to burn that stuff.
on
1 Post
I think you are right the reason BD tends to burn cleaner is because it is oxygenated while petrol diesel is not.
Does this mean we can look forward to diesel regulations that require oxygenation much like we did over the last 15 years with gasoline in California? I sure hope not but I can see it coming.
If corn (ethanol) is the answer to gasoline oxygenation, then maybe soybeans (biodiesel) is the answer to diesel oxygenation.
BD is more environmentally friendly than Petro for several reasons. Even B2 shows reduction in CO and CO2. Pure BD is CO2 neutral in that all of the CO2 released was initially removed from the atmosphere by the plants that produced the oil seed crop.
Additionally BD is biodegradeable at about 3X the rate of Petro so spills are less problematic
AK FORD GUY
33
06-04-2017 10:25 PM
CanMoose
03-13-2017 03:50 PM
1985L8000cat3208
08-14-2016 09:27 PM
Lobanz
05-30-2016 03:15 PM
ExPACamper
54
10-19-2015 06:20 PM
