camber adjustment
Old 05-06-2006, 05:47 PM
mackdog's Avatar
mackdog
mackdog is offline
Question camber adjustment
On a 1992 F 250 4x4, is it possible to adjust the cambers on the front axle, on my truck the front right tire wears on the outside edge. I know the ball joints are good. Is this something that a professional has to do. What does it take to make the adjustment and know if it is right.
Old 05-06-2006, 06:24 PM
F150xlt's Avatar
F150xlt
F150xlt is offline
There is a bushing that surrounds the top ball joint. Changing the bushing is how you adjust camber.
The factory offers bushings in 2 degree increments.
http://www.superlift.com/accessories...b-bushings.asp
Superlift offers one bushing that is adjustable. When you have a wheel alignment done, they can tell you what the camber is.
Old 05-06-2006, 09:40 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
It's something you should have an alignment machine to do. Bushings are available to adjust camber and caster at the same time, both of which can cause pulling to one side. Plus anytime an adjustment is made, toe will have to be readjusted, which is a major tire wear angle.
SoCal949
2009 - 2014 F150
05-04-2014 08:24 PM
Ganz
1997 - 2003 F150
10-10-2007 05:32 PM
BARNYARD
02-02-2005 10:24 AM
Seifferlein
06-29-2003 12:53 PM
Quick Reply: camber adjustment
