Disabling PATS
Originally Posted by mgraveman
I am getting ready to put a modular from a 1997 E350 into an 82 F350, and am wondering how to disable PATS so that it can run in an older truck.
Any ideas?
Any ideas?
And then get a computer with that code from a junkyard?
Does the PATS system just use a resistor in the key like the GM's around that time? If so, you can get a resistor of the right value and wire it in and get around it.
I just did some research, and it looks like the Ford PATS system is a transponder-based system. Not easy to bypass.
Look at remote-start systems, they do sell PATS bypass modules that are basically programmed with the transponder code (2 keys required) and then there is a wire loop that transmits the transponder code to the computer. Nice hack.
However, there HAS to be a 5.4/4.6 computer that doesn't include PATS that you can use... again, ask the dealer's parts dept.
Good luck! And let us know how it works out and what you did to bypass it.
Fully_Loaded
12-04-2009 12:06 PM
