Air Starter
not sure on how much the starter would cost...
You would have to run an small compressor and a small air tank to power the starter. Maybe a .5 to 1 gallon tank. And just wire the compressor to kick on after the truck has fired up.
I looked at some earlier that operate at 90 psi and only pull .25 cfs (cubic feet per second)
You know how an impact wrench sounds? Its kinda like a cross between and impact wrench and a singing turbo.... Louder and higher pitched than an impact and louder and deeper than your turbo. Sharp and crisp sound.
The ones used for those monster 3512's is deafening...
You will never forget what one sounds like when you first hear it go off. I hit the deck because I thought the SOB was about to blow-up, all of the experienced hands laughed at me :-/
Muuuhahah!
Click here for a crappy clip, but all I could find. http://www.citlink.net/~tcrandall/RoadWarrior.wmv
Air start systems work well on large (very, very large) diesel engines that a starter motor could not turn over.
The air start system pipes high pressure air to each cylinder from a distribution manifold and though air start check valves to each cylinder. The systems I'm used to run with 175 psi starting air pressure and will spin a diesel engine until it starts.
After maintaining the air start systems, I'm glad that my truck has a starter motor....
Lou Braun
Lou Braun
