Optimum temp for WVO and other ??
Old 04-23-2006, 09:38 PM
sgrol's Avatar
sgrol
sgrol is offline
1. Is there an optimum temp for the wvo to run in a PSD?
2. Is there a temp that's too hot ?
3. How long can you store wvo from the restaurants? ( I would like to stock up now so when I get converted I'll have a supply going.) Thanks to anyone for replys.
Old 04-23-2006, 11:42 PM
Orpackrat's Avatar
Orpackrat
Orpackrat is offline
I think but do not know for sure that you do not want a temp above 200 degrees but about 150 degrees. FABMANDELUX is the one to ask, he know much more than I do.
Old 04-23-2006, 11:45 PM
Orpackrat's Avatar
Orpackrat
Oops I put above 200, I meant below 200 and above 150.
Old 04-23-2006, 11:47 PM
Orpackrat's Avatar
Orpackrat
Oops again, I misread my first post,
mabe it is time for me to go to bed.
Old 04-24-2006, 04:23 AM
leskwvo's Avatar
leskwvo
leskwvo is offline
#1 150-160 F is the number most shoot for. In a PSD that is hard to measure sine the injectors are in the heads a long with the fuel rails. Most think the PSD is the perfect engine for WVO. It has built in fuel line heaters. I get oil going into the heads at about 145-148F so I have to assume I'm picking up even more heat from the heads.
#2 In a PSD there probably isn't a too hot temp. Since we don't have an IP we don't need to worry about overheating it. But, how your heating it to that temp could be an issue. If you use some sort of electric heater to heat it you always want a filter of some sort after the heater.
#3 Not sure I've read 6-9 months if it's unfiltered much longer if it filtered and dewatered. I use mine pretty fast so I've never have any around more then 2 months.
natedog37
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-08-2011 01:02 AM
Bubba828
04-01-2009 11:23 AM
dzzavid
03-06-2008 08:04 AM
onioncasserole
11-03-2005 08:51 AM
myjack
03-14-2005 06:07 PM
Quick Reply: Optimum temp for WVO and other ??
