92 F250 7.3 IDI want to run on WVO
Old 04-22-2006, 09:47 PM
rogerpemberton's Avatar
rogerpemberton
rogerpemberton is offline
I live in Central Texas and I am hoping that our warm weather will prevent me from having to heat my oil.
I plan on running 5-15% Regular Unleaded Gas with the WVO to keep it thin. Probably on the low end during the summer and higher in the "winter."
Is anybody doing this with this year diesel?
Are there any issues I should be aware of? How does the fuel pump hold up?
Thanks
Old 04-23-2006, 06:32 AM
leskwvo's Avatar
leskwvo
leskwvo is offline
You are asking for trouble running unheated WVO. Do some mre internet searching and I think you will find the only safe way to run WVO is in a heated system.
Old 04-23-2006, 11:40 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Like Erick said, Bad,Bad idea. Unheated WVO will cause coking of the injectors, and will build up behind the rings and cause excessive cylinder wear.
The addition of gasoline is a bad idea too, gasoline has a lower vapor point than diesel and will ignite sooner. this causes excess cylinder pressure, and higher cylinder temps.
Either make Biodiesel, or use a heating system to heat the WVO.
FABMANDELUX.
onthemoveactivist
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-13-2014 12:42 AM
naturescape
11-10-2010 08:04 AM
Orpackrat
10-14-2006 12:03 AM
parkland
17
03-27-2006 03:02 PM
Quick Reply: 92 F250 7.3 IDI want to run on WVO
