Fuel Heater for VVO
Old 04-09-2006, 01:27 PM
MobeyDick's Avatar
MobeyDick
MobeyDick is offline
Fuel Heater for VVO
Does anyone know of a Fuel heating system for a 01, 05 & 06. I plan on running B50 all summer but next winter that may be a bit much. It don't get real cold down in South GA.. Next year I would like to run SVO-VVO all year!!
Old 04-09-2006, 03:24 PM
leskwvo's Avatar
leskwvo
leskwvo is offline
Running B50 probably will not need heat any time of the year down in GA. I think you'd be good to about 20F or so before you'd need any sort of heat. But then you could always run like B20 or something in the real cold week or two you get.
Fab should be able to confirm this.
Old 04-09-2006, 04:24 PM
MobeyDick's Avatar
MobeyDick
I want to run SVO 100% all the time!!
Old 04-09-2006, 06:17 PM
leskwvo's Avatar
leskwvo
leskwvo is offline
well then you'd want to convert the vehicle. We have kits for 2nd gen 7.3s and 6.0 PSDs.
Take a look at www.plantdrive.com.
Old 04-09-2006, 07:07 PM
MobeyDick's Avatar
MobeyDick
Went over there and looked at that!! If I lived above the mason Dixon line I might do that. I don't, Thank God!! I don't think I would have any trouble running VVO during the Summer 8 Months down here!! They had a 12V in line heater that looked like something I might get!!
Old 04-09-2006, 07:47 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Right again Eric, I use B-80 in the winter with no problems. He should be able to run B-100 for 11 mo in Ga and maybe run B-80 in the one cold mo.
I built a couple of heaters on our big rigs just to help pre-heat the bio. I took a 3/8" steel tee and used a glow plug in the tee side and run the fuel through the straight side. I put it just before the IP, seems to work just fine.
FABMANDELUX.
Aford92
02-07-2017 04:32 PM
Brenda Lamka
20
12-16-2016 04:18 PM
JAZ8602
16
09-02-2016 09:35 AM
terrynbama
1983 - 2012 Ranger & B-Series
10-12-2011 08:07 AM
mackdog
06-14-2006 08:00 AM
Quick Reply: Fuel Heater for VVO
