Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
puller tool for power steering pump pulley
Old 06-09-2002, 11:06 AM
hkmp5sd's Avatar
hkmp5sd
hkmp5sd is offline
Post puller tool for power steering pump pulley
I'm ready to replace my power steering pump in my 1992 Ford F150 4.9L six, pick up truck.
I am trying to find out the correct Snap-on puller for this job.
Any help would be appreciated. It seems like a staight forwrd process but any tip for this replacement would be appreciated.
Thanks.
Ray Barnes
Old 06-09-2002, 12:44 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
These type pullers are quite expensive to buy.
You might be able to borrow one from autozone because of their "lend a tool" program.
Other parts place have a tool program also.
Good luck.
*Lisle* makes one that cost $100.00 here in Canada
[font color=red]Dennis
Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTEModerator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old 06-11-2002, 11:49 AM
charlez's Avatar
charlez
charlez is offline
If you aren't going to use it very often you may be better off just buying a cheap one. I got a HarborFreight one for $20 and have used it twice with no problems. If you do get one, make sure it will both pull and then push on the pulley, some brands sell them as two seperate tools.
Old 06-12-2002, 01:11 PM
brokebronco's Avatar
brokebronco
brokebronco is offline
go to the snap on website. they are pretty expensive. unless you plan on using it a lot i would either borrow one from a parts store or buy an inexpensive one(also from the same parts store)
Old 06-12-2002, 09:03 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Old 10-20-2005, 09:42 PM
gdawghereiam's Avatar
gdawghereiam
gdawghereiam is offline
2 push the pulley back on the shaft,use a bolt screwed in2 the ennd of the shaft with a jam nut on a flat washer.position the pulley and tighten as the washer presses on the pulley.
Old 10-22-2005, 03:07 PM
SDRULES's Avatar
SDRULES
SDRULES is offline
Those pulleys are difficult at best to get off. You can get a pump with a pulley at Auto Zone for not that much more and save the aggravation.
Old 10-22-2005, 03:21 PM
chowitworkz's Avatar
chowitworkz
chowitworkz is offline
For less than professional use I would get a less expensive puller. Also any pump that I have ever replaced always came with a bolt for pushing on the pulley. A pulley is not at all difficult to pull with a proper tool. The difference between the ease of most tasks for the pro or the shade tree mechanic is the quality of his tools.
Old 10-23-2005, 09:28 PM
gdawghereiam
when u get the p/s pump at autozone,the pump they give u has no pulley.i rented a puller from them.i pulled the pulley and put it on the new pump using the bolt/flatwasher/nut.
Old 10-23-2005, 10:40 PM
SDRULES's Avatar
SDRULES
SDRULES is offline
They sell the pulley seperate. You just have to ask for it.
Old 11-01-2005, 05:00 PM
afinepoint's Avatar
afinepoint
afinepoint is offline
I agree. Rent don't buy. It is a tool you'll use once in a blue moon. If ever again. When I changed the pump on the Explorer I "rented" the tool from Pep Boys. I left a deposit and when I returned the tool I got the deposit back = FREE. This policy is not uncommon.
Good luck.
Reg
Old 11-02-2005, 10:35 AM
Bart99GT's Avatar
Bart99GT
Bart99GT is offline
On some vehicles the pulley has to come off to get the pump out of the mounting bracket. Chalk up another one for the geniuses at Ford.
Old 11-02-2005, 11:15 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
I bought a p.s. pump pulley for about $20 at Advance Auto Parts or Autozone (I forget) and it worked well enough on a Chevy with an impact tool. I can't see the Ford being worse.
Old 11-03-2005, 03:58 AM
fellro86's Avatar
fellro86
fellro86 is offline
I bought the Lisle tool for $47, it also is an installer. Sure is handy to have... if you have a Lincoln or Taurus type engine, you need it to be able to get the ps pump off if servicing the head gasket or such... the Lisle tool is also universal, will work on Ford, GM, and Chrysler for a minimum. Snap On will likely have it as a Blue Point. If you really want Snap on, here is the page: Snap On puller They make you buy a bunch of pieces to do the same thing the Lisle does for less pieces and price. I bought my set from Northern Auto, northernautoparts.com, for $47, item # is 38850. (link was blocked)
Shadowrider123
16
01-02-2018 06:02 PM
creedua
19
06-11-2014 01:01 PM
blageurt
02-19-2014 06:59 PM
'78F250351m
16
07-11-2011 02:51 PM
mrdavidkendall
12-29-2004 05:46 PM
Quick Reply: puller tool for power steering pump pulley
