Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Spark plugs and gap?
Old 03-24-2006, 07:17 AM
mnalightning00's Avatar
mnalightning00
mnalightning00 is offline
i am about to change plugs in my 00 lightning, mods include diablosport predator, 90mm mass air, k&n cold air intake, and a flowmaster dual exhaust kit, question is what plugs to buy and what the correct gap should be. and does anyone have a step by step process on how to cahnge plugs on a 00 lightning?
Old 06-24-2006, 11:13 PM
Lightning Rod's Avatar
Lightning Rod
Lightning Rod is offline
I did not see a pulley listed in with your mods, so I'll assume you're running stock boost levels. The factory platinum plugs or NGK TR6s work well for your application. Might want to gap them around .041 to reduce the chance of detonation.
When adding extra boost, the rule of thumb is to squeeze the gap down .001 for each pound of added boost. The stock plugs are gapped at .042, so if adding a 4 lb. pulley, you'd want to gap the plugs at a tight .038
Old 07-13-2006, 09:05 PM
gbgary's Avatar
gbgary
gbgary is offline
____________________________
gary
Old 08-01-2006, 05:43 PM
evo's Avatar
evo
evo is offline
According to that chart it says I should be gapping my plugs at .036. I have Denso's 22's and I gapped them at .032 that's with a port and a 6#er. If I gapped them at .036 I would be afraid of spark blow out.
Old 08-01-2006, 06:20 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
If it idles and drives fine, then there is no need to open the gap.
Old 08-16-2006, 08:14 PM
gbgary's Avatar
gbgary
gbgary is offline
i have ported blower and six lb. lower and i gapped my denso 22s at 37. no problems with blow out.
gary
Old 08-16-2006, 08:17 PM
gbgary's Avatar
gbgary
gbgary is offline
double post.
Old 03-24-2011, 11:33 PM
magoo123's Avatar
magoo123
magoo123 is offline
spark plugs
I have a 2001 lightining low miles upgrades 6 lb pulley,shift kit ,programer chip,Electric fan .Question: plugs are stock need to change them out i was told to use a colder plug. any one have any good ideas on what plugs to use and gap. thanks.
nintey4f150
05-09-2017 07:24 PM
dobenator
12-06-2016 12:06 PM
bigcrunch
12-05-2009 05:05 PM
EXPLORER GUY
12-01-2006 10:49 AM
ssKable
03-05-2005 12:46 PM
Quick Reply: Spark plugs and gap?
