Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
ABS light on, not rear speed sensor, HELP!
Old 03-09-2006, 06:10 AM
aplustechnician's Avatar
aplustechnician
aplustechnician is offline
Question ABS light on, not rear speed sensor, HELP!
Just about every other time I start my Explorer up the ABS light comes on and stays on until I turn the engine off and then restart. I have tried changing the rear speed sensor (on the differential) and that didn't affect it. Has anyone else had this problem and how did you fix it? (Yes, I 'm trying to avoid taking it in to the shop!)
Old 03-09-2006, 07:02 AM
rangerguy52's Avatar
rangerguy52
rangerguy52 is offline
I have the same problem on my '97 Explorer Sport. I've done the same thing and had the same outcome. I have no cule on how to fix it mine has been like that since September. If you find a way to fix it please let me know.
Old 03-09-2006, 11:18 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
See if your Haynes or Chiltons tells you how to pull the ABS trouble codes. Odds are you'll get a code for one of the front wheel ABS sensors.
On older Fords there was a seperate test connector for pulling the ABS codes, dont know about yours.
Old 03-09-2006, 12:55 PM
rangerguy52
I did pull the codes for the abs and I got a code saying something about the rear axle speed sensor. I can't remember what the code was, I have it wrote down at home.
Old 03-09-2006, 07:37 PM
aplustechnician
I have recently replaced my front hubs, but it could still be the front sensors. Can you buy a testor to pull the codes with?
Old 03-10-2006, 01:33 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
Well I did some poking around and what you need to pull the ABS codes is an OBD-2 scanner that is capable of also pulling Ford ABS codes.
If you have an Autozone nearby they will pull codes for free. But ask them if their scanner is able to pull the Ford ABS codes.
I sure hope that ABS remains an option that I can just say NO to when I buy my next truck.
Old 03-10-2006, 05:28 AM
aplustechnician
Thanks for the suggestion 87. I will go by there today and see if they can pull the codes. I will post the results if they do.
Old 03-10-2006, 03:48 PM
aplustechnician
I took it in to a local garage and the mechanic put a Snap-on code reader to it, and it indicated a bad ABS pump (big money). I am still thinking about taking it to my local Ford dealership and have them check it to be sure. I tell you the truth, those Toyotas are looking real good now!!
Old 03-13-2006, 04:43 PM
aplustechnician
Rangerguy, just to follow up, I took my Explorer to the dealership and it turned out the first mechanic was wrong. It was the front sensor after all (which is wonderful considering the pump I don't need is $1500 and I have two spare sensors which I do need already!!) I am very relieved!!
Old 01-13-2008, 04:01 PM
mc320's Avatar
mc320
mc320 is offline
where exactly is the rear sensor located?
I got a code that says the rear wheel speed sensor is bad and I see that several of you on this thread have replaced it. Would someone walk me thru the steps to 1) get to it and 2) replace it? I am now trying to go at it from the rear by removing the spare tire and the plastic moldings that surround the spare tire. Am I on the right track? Can you post some pics?
Old 01-13-2008, 04:30 PM
thelonerangerxlt's Avatar
thelonerangerxlt
thelonerangerxlt is offline
mc320, it's much easier to go at it from the driver's side. Just jack it up and put jackstands under that side, enough to allow you to crawl under it. You can reach up and remove one bolt, maybe an 8mm or so, then pull the sensor directly out. There's one electrical plug-in for it.
It's easy to do, but the sensor is up where it's hard to access. You'll have to go by 'feel' to loosen and tighten the hold down bolt, but it's about a 15 minute job.
zrt600guy
1983 - 2012 Ranger & B-Series
02-14-2012 04:10 PM
blee1ash
03-08-2011 11:55 AM
tivoklr
01-28-2010 11:09 PM
njxlt
12-28-2008 02:40 PM
Quick Reply: ABS light on, not rear speed sensor, HELP!
