New 6.7 Cummins & New Dodge Frame Formally Introduced
http://www.turbodieselregister.com/06ntea/
Looks like Daimler has dropped the boxed-section frame on their heavy commercial truck and adopted a C-section frame like the Super Duty.
Also, note the conservative numbers listed for the new motor and take a look at the new 6-speed automatic transmission.
Guess Ford had the better frame design all along.
-Mike
-Mike
The boxed frame is nothing more than the company trying to gain a marketing advantage over the other. The boxed frame does however add alot of extra weight, and a C frame has proven to be more than enough on light to medium duty trucks. It provides proper flex and enough strength for most any job these trucks will see. Its also lighter, and much cheaper to make.
Look at how straight and low profile that frame is, closer to a tractor trailer frame. No uneeded bends or twists.
Damn the new dodges look hot as hell.
Took them long enough, but it looks like they are going in the right direction. As others have said it's about time Dodge faced the fact that they can't build a transmission worth a damn. I'd be interested to see how the engine performs with all the new systems they have put on it. The magazine article makes it sound great. It is a completly new engine design so I would expect some bugs to appear. When will they start making the outside of the truck look better?
Originally Posted by RY54
"We asked if this transmission (new 6spd auto) was going to be used in the regular 2500 and 3500 trucks and were told that the '07 model will continue with the 48RE."
This doesn't make any sense, unless its a cost/fitment issue....
Galizien:
The boxed frame- as used by D-C in the 2500 and 3500 actually weighs LESS than the C section Ford due a lighter gauge steel. You are correct about flex though- All other things being equal, box section frames tend to be stiffer up to the point where they fail- and C section frames handle deflection better.
The trade-off is that a frame that flexes will make a poorer handeling truck- soft. But stiff frames tend to fail when abused.
I guess one probably makes sense for lighter trucks where overloading is not going to be a significant issue and the other frame makes sense once you are in the range of trucks where frames simply have to flex in order not to fail.
-Mike
Originally Posted by Batgeek
Agreed the story got wierd at the end stating that the new engine, transmission, and frame would not be used in the regular 2500/3500. Tell me if I'm wrong, but I thought that the 5.9 would not meet the 2007 emmission standards. I see alot of Dodge lovers buying chassis cabs and ordering beds to put on them. I know I would if Ford came out and said "we are only putting the new 6.4tt and 6 speed auto in the chassis cabs". Of course they may be doing it this way on purpose. They won't sell as many chassis cabs as they would regular trucks, but the chassis cabs will see more use in a shoter period of time. This would give them a "test market" to work any bugs out before it went into large scale production. I'm probably being paranoid.
Originally Posted by ford4.9
" While this system is much more complicated than the existing high-pressure, common-rail engine. However, it has been used by Cummins since 2002 with 300,000 engines currently on the road and over 30 billion miles on the road. "
Ford/ Navistar did that!! It's called the 6.0
The statistic seems a bit odd.
-Mike
