1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
4wd light flashing constantly...help!
Old 02-20-2006, 05:40 PM
showstopper151's Avatar
showstopper151
showstopper151 is offline
First off the truck is a 99' Expedition (E.B. 5.4) and the 4wd light comes on and flashes constant until I turn it off and restart it then it does not come back on. I noticed it does it when it is cold, and when I turn the wheel like it is engaging it somehow??? After the truck warms a bit I can restart the motor and all is well but if it is cold out it just does it again. Also I notice the tires are sticking, almost like pushing sideways when I try to turn the wheel in the morning and they kind of clunk a bit causing the 4wd light to come on and flash constantly. Is this coincidence? Thanks for any input. I really hate to pay the high dollar at the dealer so anything you pro's can come up with will be greatly appreciated.
Old 02-20-2006, 05:50 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old 02-20-2006, 07:46 PM
scottspoerry's Avatar
scottspoerry
scottspoerry is offline
Could be Speed Sensor
Could be a bad speed sensor on the transfer case...they will cause flashing 4x4 light.
Old 02-21-2006, 08:58 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Could be several things.
Need to have the codes pulled. You'll need a scanner capable of pulling Ford-specific codes. Don't know if the cheapos will work, but it's worth a stop at AutoZone.
Steve
Old 02-21-2006, 09:30 AM
the4by4freek's Avatar
the4by4freek
the4by4freek is offline
Autozonw cannot pull the codes for your 4WD. You definately have a sensor gone. Only Ford or a good transmission shop can pull the codes from the transfer case sensors. It sounds to me like your hall effect sensors are bad.... there are 2 of them. I hope this helps.
Old 02-21-2006, 04:46 PM
showstopper151
Thank you all for the info. I will get it looked at over at the ford dealer. Hopefully it will not be too expensive.
Old 08-20-2006, 11:38 PM
Johnny60546's Avatar
Johnny60546
Johnny60546 is offline
Question Blinking 4x4 light
The 4x4 dashlight on my 99 xlt w/79000 just started flashing tonight(Sunday 8-20). It shifts into 4h and 4l just fine, but in AWD the dash light blinks... It doesn't exhibit any of the symptoms as noted in previous posts... She drives fine, and except for the wipers coming on when I open the drivers window and the rear wiper only working when it's NOT raining, she has served me well... I searched posts here at FTE and I looked in the original owners manual but to no avail... Of course, I might just be not that smart and missed them... I wish my OD light was blinking... I would have solved that an hour ago...
I also have a recall notice for a speed control deactivation switch... Possibly related???
Old 08-12-2012, 09:54 AM
Countryfied's Avatar
Countryfied
Countryfied is offline
Does anyone know what the ohms are supposed to be on transfer case sensors? would like to test before buying,also the relay switches as well in the dash what they should read ? I've been trying to locate the transmission sensor but to no avail ( I must be blind) is it on this truck? already tested sensor on rear diff. thanks to info here thats fine 4x4 lights flashing got codes P1837 (transfer case sensor ) and C1107 this is on a 1999 navigator 4x4 5.4 any insite on this would be appreciated ,It feels like its 4wd until I get to 30mph then 4x4 light starts flashing I did just have a wheel bearing replaced on front drivers side but flashing was there before that and odometer is flashing but I think I seen the fix for that I have not done the odometer thing yet Thanks (This site has tons of info so glad I found it !
devongarver
6.2L V8
17
04-01-2021 05:55 PM
alduane
1983 - 2012 Ranger & B-Series
20
08-04-2016 07:57 AM
dyhrdford
1999 to 2016 Super Duty
04-16-2009 07:22 PM
ARTURO TOSCANO
08-19-2002 12:43 PM
Quick Reply: 4wd light flashing constantly...help!
