302 spark plug #? Autolite 45? 46? higher? What do you run?
I have a 302 from 73' 2bbl Holley, the PO said it has a "mild" cam. It has never idled right and I'm playing with plug heat ranges now, seems like it loads up at an idle, but wont idle when lean either. I have been over all the "normal" stuff, cant figure it out...
What # plugs are you running in your 302? How hot can I go?
Sounds like it might be carbon build-up, runing the engine at a fast idle, you can trickle (very, small) water or ATF fluid down the carb to dissolve/break it up. In regards to plugs, you can go up or down 1 step but timing & fuel mix will need to be adjusted. I'm betting it is either carbon or an electrical based issue though.
All good advise. Bought a vehicle about a year ago with same issues and black plugs. I did go up one heat range, but have slowly cleaned engine and carbon deposits running Seafoam and a little Marvel Mystery in the oil. Keeping a close watch on condition of the plugs, have had to go back to the colder plug and back off timing a couple degrees.
RileyCarroll
12-29-2019 07:25 PM
Tim Harper
06-17-2016 08:25 AM
dozernsasha
19
02-12-2016 10:36 PM
