Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
egr problem
Old 01-17-2006, 09:33 PM
MintHill68f100's Avatar
MintHill68f100
MintHill68f100 is offline
egr problem
my 94 lightning seems to be cloggin up the egr valve regularly, as in every couple hundred miles. is there anyone that knows why. i havent brought myself to buy a new one yet bc they are so expensive and i can only find them at the dealership. but i mean cleanin it out helps it for a lil while and then the engine light comes on.
Old 06-07-2006, 12:11 AM
ejay115's Avatar
ejay115
ejay115 is offline
I had that problem on my 94 Lightning. The check engine light would come on every so often, I would have to un-stick the plunger in the EGR valve. I eliminated the smog pump and associated equipment, and when I removed the intake to get to the plugs in the head, I noticed that the intake runners were very dirty, and I think that the gasket on the coolant side of the EGR spacer was leaking, causing coolant to go into the EGR valve. I had another problem of coolant going somewhere, and couldnt find out where.
So far, I have not used any more antifreeze. Maybe that was it, but I cant be sure cause with the smog equipment gone, the light come on all the time......
Which is my problem, how do I get the EGR out of the check engine light system....
BTW, I will post a step by step list of what I did to get rid of the smog pump when I am sure everything is ok..... after 800 miles, so far, so good....
Old 06-09-2006, 09:36 AM
MintHill68f100
u have to purchase a twEECer to reprogram ur ecm to take the egr out of the system
brkncly
6.4L Power Stroke Diesel
08-02-2012 08:25 PM
pnj442
09-29-2010 07:46 PM
jasonwf350
07-10-2006 06:07 AM
JCastellaw
01-16-2004 11:35 AM
DRanchero
07-30-2003 09:23 AM
Quick Reply: egr problem
