1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
2000 Ranger Wiring Diagram
Old 01-14-2006, 04:48 PM
mrblonde's Avatar
mrblonde
mrblonde is offline
I've got a 2000 Trailhead Ranger, 3.0 engine, 2wd. I had major corrossion in connector c309, which is located under the driver's seat. This caused several codes, and no signal from the RABS sensor. Anyway, while taking care of this problem I must have reconnected some wires incorrectly. Does anyone have a diagram for this connector, or maybe what diagram I should ask for at the dealer? Thanks in advance.
Old 01-14-2006, 05:53 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
Welcome. The best I can do for you is this:
The RD/PK (pin 17) and the LG/BK (pin 21) wires are for the rear ABS speed sensor.
HTH
Old 01-14-2006, 05:58 PM
Ken00's Avatar
Ken00
Ken00 is offline
Rock got to it first.
Old 01-15-2006, 11:26 AM
mrblonde's Avatar
mrblonde
mrblonde is offline
Thanks a lot guys. You wouldn't be able to get your hands on the diagram for the male half of the connector, would you?
Old 01-15-2006, 07:37 PM
Ken00's Avatar
Ken00
Ken00 is offline
The wire colors are the same on the male side, the pins are switched side to side, pin 1 is pin 6 and 6 is 1.
Old 01-16-2006, 05:59 PM
mrblonde's Avatar
mrblonde
mrblonde is offline
Oh, OK, thanks again guys
BearFootCustom
07-18-2016 08:24 PM
madizon1420
04-15-2016 06:36 PM
turbo06
2015 - 2020 F150
08-22-2015 05:05 PM
Roy C
01-06-2010 05:52 AM
F250Wheels
07-25-2005 12:13 PM
Quick Reply: 2000 Ranger Wiring Diagram
