429 horsepower rating
Well a 429 4 barrel (4V stand for 4 venturi, the 429 has 16 valves) with ported & polished D0VE heads is hardly stock and the definition of "ported & polished" is pretty generic. The factory rating for the 69-70 429 ThunderJet with 11:1 compression and a 4V carb was 360. That was SAE gross HP which consisted of dynoing the engine with no accessories and a minimal exhaust system. Some say that it was over rated for advertising purposes although the 429 CJ was rated at 370 HP and the consensus seems to be that it was under rated for insurance purposes.
If and that's a big if, the head work was done correctly there could easily be an additional 30-40 HP depending on the exhaust configuration. If all they did was hog out the ports & gasket match then it's probably just a 429 block with a pair of iron paperweights bolted on top.
The factory rating for the 429 CJ was 370 HP @ 5400 RPM/450 TQ @ 3400 RPM. I have a stock 429 4V ThunderJet in my 1970 XL. It pushes that 3800 lb car around just fine even with the tall rear end gears. The only modifications to the engine are a Pertronix Ignitor ignition module and a BG Demon 725 CFM carb.
Originally Posted by 351m_torque
should this engine be enough to push my 78 f-150 around with still quite a bit of power? i have a 3.50 gear ratio with 33 inch tires
ryceman168
04-23-2014 01:39 PM
006f350diesel
07-15-2006 01:02 AM
oldyeller
16
02-02-2006 07:24 PM
1972 Ford Thunderbird 429 V8
11-21-2002 06:04 PM
