Has anybody come up with a solution? I just found this out over the weekend. For some reason, Ford designed things screwy. I for one, would like my fog lights to stay on while the high beam headlights are on. My friends Toyota is the exact same way.
no need for a new wire. do a search for this. you need to ground out a prong in the relay. also the law has nothing to do with Fog lights by themselves . it simply states it is illegal to exceed a certain amount of watts. this is a serious offense here in cal will run you 500.00 and a fix it ticket.
I DID do a search first. Wouldn't you? I looked up fog lights under the Lightning section. I read for two days (not quite), but found nothing of what I needed. Any better help, then "do a search"?
Look up the law before you dismiss what someone else says. Who knows? They just might be in possession of a fact or two that you are unaware of.
