1999 F150 fuse configuration - heater
Heater blows cold air, there's no anitfreeze leaking into truck. Just wanted to check the fuses to see if there is a related fuse that might need replacing. Can't think of anything else short of taking it in to a mechanic. Pulled off fusebox cover but don't have an owner's manual that shows the configuration. Does anyone know if there is a fuse for the heating system and where it's located and the fuse rating? Thanks! Steve
on
1 Post
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to 97-2003 F-150 forum.
See ya on the boards!
-Matt
P.S. Here's an idea. Start the truck up and let it run for a while. Is the temperature gauge the normal area? Also, feel the radiator hoses. They should be hot. If they are cold or barely warm then it could be a thermostat that is stuck open. Good luck!
-Matt
Taylor Anderson
10-24-2016 01:20 PM
NickOlsen53
04-13-2014 02:11 PM
