can a 477ci go into a 79 f250 or a beefup f150
hi, i just got a 477ci gave to me and it was rebuilt plus trans and i like to know if it can go in to my 79 f250 or can i put it in to my beefup 79 f150, both trucks had a 351m in before and both are 4x4 also, hope someone can help.thanks gene,
Okay, just kidding about the sarcasm, but that's what your F250 or F150 will be saying if you ATTEMPT to put that motor in. The 477 weighs about 1300 pounds. That's about 800 pounds more than your 351M. How long will the front end of your truck last?
The 477/534 is also a very low RPM motor, 3300 max. Gas mileage is about 3 miles per gallon and NO speed parts are available.
Stick with your 351, or if you absolutely need the cubes, drop in a 460. Good as it was, the 477/534 is an antiquated motor that Ford stopped building for a reason.
54Hydro
10-24-2016 04:37 AM
F1truckproject
06-18-2013 01:57 PM
