front tire lean
Ford wheels are supposd to have a lean, try backing up and check them you will swear they are falling off. I wish I could get mine back to OEM factory specs for that softer ride with NO tire wear. Due to the crown in the road the highways dept use Ford adjusted the angle so your truck would steer right.
Check the front spring shackle.
The end up inside the frame seems to be the one that wears the most.
I had this clunk when I hit a pothole that I looked for for a year or so, never could find it.
I replaced my springs and shackles last summer.
When I pulled the front shakle out of the frame I found the clunk, the top bushing was gone on both sides.
The new springs had an extra leaf in them.
The shackle did more to raise the front of the truck than the extra leaf did.
Also the negative camber was reduced considerably since the front end sat higher.
drumminguy81
12-02-2010 07:10 PM
grizz3000
16
12-19-2006 11:48 PM
paradiseandpalms
10-27-2006 08:28 PM
