NP203 oil and capacity?
Old 12-03-2005, 04:08 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
Question NP203 oil and capacity?
Ok, I can't remember what oil goes in the 203 and what is the oil capacity.
I want to say 30W motor oil, but not sure if 10W30 or 10W40 would be preferred.
Also 7 quarts sounds right, but don't remember.
Thanks for any comments.
Old 12-03-2005, 10:49 PM
7FORD2's Avatar
7FORD2
7FORD2 is offline
ok its 10w40 and its 9 not 7 quarts
Dustin
Old 12-04-2005, 08:00 AM
MBBFord's Avatar
MBBFord
MBBFord is offline
Thanks for the help, I couldn't remember.
Old 12-04-2005, 08:06 AM
The SnoMan's Avatar
The SnoMan
The SnoMan is offline
Dustin
It is supposed to be straight 30w non detergent oil. You can use straight 20w in winter. You do not want to use a multi vis detergent oil which will not lube it as well and tends to foam up in case too! (non detergent oil will not foam)
Old 12-04-2005, 08:44 AM
MBBFord's Avatar
MBBFord
MBBFord is offline
I've seen both use, I've actually seen people use 90W and sware that's what is suposed to be used, but it is 9 quarts of 30W right?
Old 12-04-2005, 01:09 PM
The SnoMan's Avatar
The SnoMan
Yes or until it runs out of fill plug. I cannot varify capacity in manuals here but I can varify the 30w. I am thinking closer to 7 quarts though. I was driving when they first came out and remember that Tcase well!!
Old 12-04-2005, 06:56 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
I'll try doing some more research, but thanks for the info so far guys.
Old 12-05-2005, 05:12 PM
1975Ford's Avatar
1975Ford
1975Ford is offline
I've seen on a shop manual and it's calling out 50w on t-case.
Old 12-05-2005, 08:32 PM
7FORD2's Avatar
7FORD2
7FORD2 is offline
ok guys this what my 79 ford truck manual says its 9 quarts of 10w40
Old 12-05-2005, 09:11 PM
The SnoMan's Avatar
The SnoMan
The manuals are in error. I remember when those things were new. New Process (who made the case for Ford, GM, Dodge and IH) spec'd it for striaght 30W non detergent oil in summer and you can use striaght 20 in winter if it gets below zero a lot. DO NOT USE MUILT VIS OIL regardless of what manuals may say as it lasts the longest with regular changes of non detergent oil which does not foam like muiltvis oil can do with the high chain speeds at times in that Tcase. All of those engine additives in modern muilty vis oil are of no value to keeping your Tcase alive.
Old 03-28-2015, 09:29 AM
Johnny Be Cool's Avatar
Johnny Be Cool
Johnny Be Cool is offline
Ok, last post was in 2005, times have changed and there are so many different opinions on type of fluids.
Now what is the fluid viscosity used today and how many quarts?
jakeharp
04-19-2017 11:34 AM
Nussbaum
05-14-2016 08:03 PM
GeneLaw1
04-06-2012 04:02 PM
97F250LD4X
1997 - 2003 F150
12-23-2010 11:48 PM
gtm245
Oil & Lubrication
17
05-18-2004 05:01 PM
Quick Reply: NP203 oil and capacity?
