Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Gear Question (please help, new truck owner)
Old 11-24-2005, 10:17 PM
russelmania's Avatar
russelmania
russelmania is offline
Hey all, new to the forum and truck ownership.
Recently purchased a 2000 HD F150, with a Kenne Bell blower.
real dog frm the set off, but fantastic from 20 MPH and up when you kick in the supercharger.
Had a crawl around underneath and it has a 975 rear end with 355 gear.
Any sugestions on a gear that will give me the tire burning response I want???
Old 11-25-2005, 10:07 PM
harley f150's Avatar
harley f150
harley f150 is offline
The newer supercharged Harley trucks run 3.73 gears. They would probably wake your truck up. What is your opinion on the Kenne Bell blower. I would like to add a supercharger to mine and was thinking of the Kenne Bell. If you would like to see what a real dog is you could trade yours for my stock 2000. I might even be able to throw in a couple bucks for your trouble. Hahaha. But seriously, my stock 2000 will break the tires loose from a dead stop and it is equiped with 3.55 gears. Not smoke them, but you know that they are spinning.
Doug
Old 11-28-2005, 11:36 PM
Harley2003's Avatar
Harley2003
Harley2003 is offline
Smile Tire smoke = High stall convertor.
It has been my experience over the years that if you don't want to do a brake torque and get the 20" beasts spinning then you would be better off spending a few bucks on a higher stall torque convertor before changing out the rear end gears. The secret is to get the rpm's up high enough to make the power and the rest is history. I have a 2003 100th Anniversary HD (sweet) with 3.73 gears and a 2800 stall convertor from http://www.rpmoutlet.com/lighttorque.htm
This combo allows the motor to get right into the 400+ ft/lb torque range and it's quite the show I must say. Putting a 4lb lower crank pulley on the motor to raise boost to 12-13 lbs combined with a good tune from SCT or equivalent really wakes up the potential. The torque convertor is not cheap but it really improves the lower end performance. With the increased boost now coming in about 500rpm lower now, the torque band is much wider as well and comes on a lot sooner too.
I find now the truck is so responsive that I have to really watch how I leave the stop light. Too much pedal = too much attention. And I live in a small town where there is only one truck like this and they know where I live. So you get my drift. 20" rubber gets expensive too, but they keep making new tires just for that reason I guess. You only live once in this world. Enjoy it.
