2001 F-150 EGR valve problem
My Check Engine light came on this morning and I took it to AutoZone to have it scanned. The code came back as P1406 and reads "EGR Position Sensor Performance". Does that mean my EGR valve is going bad? I cannot tell a bit of difference in performance. I have a busy schedule the next few weeks and wondered what the effects are of running my truck without fixing it immediately. Thanks for the help.
How many miles on your truck? I bet it's the 4.6 liter, eh?
Remove the throttle body, change the egr valve, scrape the
egr ports clean on your throttle body, they will be full of carbon
deposits. I don't think it'll hurt your truck for just a couple of weeks,
someone with more know how tell us for sure. Be sure to disconnect
the neg. battery cable before starting, and let the truck run for
15 minutes so the computer can relearn.
yes, it's a 4.6L w/56K miles. Here's the funny thing about it though. Last December (2004) my COP on cylinder #7 went out. At the same time my DPFE sensor needed replacement. About two weeks ago my COP on cylinder #7 went out again so I replaced it. Now my computer is reading the code P1406 again detecting a problem with the DPFE sensor. It just seems so coincidental to me that I'm having two problems at the same time that occured together once before. Any ideas?
first off - nationm - sounds like the same problem. The DPFE will have minimum 1 year warranty. Return it for an exchange and remove the throttle body and clean the ports again. Also would not be a bad idea to do an upper intake de-carbon service.
zman764 - if you have code P0401 - EGR flow insufficient
The odds of the EGR valve itself being bad are about 1 in 20. If your engine is a 5.4, replace the DPFE sensor. If your engine is a 4.6, replace the DPFE sensor and remove the throttle body and clean the EGR ports.
Welcome to the forum dozer
The most common cause of EGR codes is a bad DPFE sensor.
With the engine idling apply vacuum to the EGR valve. The engine should stall or come close to stalling if the EGR valve and ports are good. If that happens then it's pretty safe to assume the DPFE is the problem. If the idle doesn't change then you have a bad EGR valve or plugged ports in the intake.
