Illinois Chapter Join Chapter Leader: wpnaes
Oil Pump
Old 11-11-2005, 08:41 AM
Edberg's Avatar
Edberg
Edberg is offline
Oil Pump
Changing the oil pump what fun it is guys.
edberg
Old 11-11-2005, 01:04 PM
Fastronald's Avatar
Fastronald
Fastronald is offline
Oil Pump
What year model truck? What engine? Could be fairly easy, could be a ....uh.pain.
Old 11-11-2005, 02:30 PM
Edberg's Avatar
Edberg
Edberg is offline
1974 Ford F-100 302 5.0
Old 11-11-2005, 04:51 PM
Fastronald's Avatar
Fastronald
Oil Pump
CAREFULLY raise the engine AFTER you have put some pressure on the oil pan with a block of wood and a floor jack.
Remove engine mount bolts and place 2"x4" pieces between the mounts to support the engine.
Drain the oil pan, remove the bolts, pull pan down.
Reach in remove the two oil pump bolts and two pick up tube bolts and slip pump out.
Remove the pan or clean the rail surface and install the gasket.
Assemble in reverse order.
Old 11-11-2005, 07:44 PM
fairmontman's Avatar
fairmontman
fairmontman is offline
You may have to raise the engine a good deal to get enough clearance,I did on my truck to change the rear main and oil pump.I would recomend using an engine hoist to raise the engine if possible.
Old 11-12-2005, 09:28 AM
Fastronald's Avatar
Fastronald
Oil Pump
Good point Fairmontman...............I wasn't sure if he had access to a floor crane though. He's right, you may have to raise it more than you expected.
Old 11-12-2005, 11:52 AM
Edberg's Avatar
Edberg
Edberg is offline
Thanks guys got it done with a floor jack
This Fourm Rocks
Edberg
Old 11-13-2005, 06:11 PM
fairmontman
Glad to hear the job went ok.
Edberg
24
11-28-2009 11:12 PM
Edberg
12-02-2005 02:56 PM
Edberg
11-26-2005 12:05 AM
Edberg
11-24-2005 02:33 PM
Edberg
11-17-2005 09:00 AM
Quick Reply: Oil Pump
