Improve your gas mileage, for free
No gimmick here, but now that the weather is "cooler", y'all might want to check your tires' pressure, cuz they're probably a bit lower than they were when you filled them over the summer.
If my physics class still serves me, there's approx a 1psi drop for every 10F drop in ambient temperature. That's not to mention tires are inherently somewhat porous to air, so they'll lose air over time, albeit very slowly. Mine were down 3psi since the summer.
I don't remember what that equates to in mpg, but every bit surely helps!
Originally Posted by 390fe
I used to work at a service station changing oil and repairing tires. As a matter of habit, I look at other peoples tires, and it amazes me how many people don't check their tires.
Tire pressure monitors are becoming mandatory for new cars soon and some also have oil level sensors instead of a dipstick.
Jim
Originally Posted by jimandmandy
I also used to work at a service station, pumping gas! That is the problem. With everything self-serv, tires and oil level do not get the weekly or so check that they got in the old days. Car owners/drivers are not any more lazy than before, acutally less so, since they have to clean the windows as well as pump gas.
Jim
Jim
Because I pull a 5th wheel trailer, I keep my rear tires at max allowable pressure (80 psi) and the front at 65 psi. It's a little harsh when the trailer is unhooked, but is smooth when connected. I also keep the trailer tires at max. (56psi) because the greatest cause of tire failure on trailers is underinflated tires, I'm told. It also helps the mileage. Running underinflated tires is like pulling a load uphill.
My on-board mileage calculator tells me I get 13.3mpg with the trailer hooked up and 19.4 running empty. That is on trips of about 100 miles or more. If the calculator is anywhere close to correct, I think that is good mileage.
busabuggy
01-01-2019 09:32 PM
cj_koser
1997 - 2003 F150
19
08-03-2004 09:05 AM
