Hole in cylinder head - ouch!
I have a '99 F-250 Super Duty (5.4L) with 263,000 miles on it. It developed a pinhole in the LS cylinder head right below the thermostat housing, causing a coolant leak. After sticking it with a screwdriver, I ended up with a 1/2" hole!! Has anyone ever encountered this? I can't even drill & tap it as it is near the top of the head where there is a bend in the casting. I really don't want to pull the head off - is there some "super epoxy that will stand up to the coolant temperature/pressure? Thanks.
OK - I went the JB Weld route. I hammered out a 1/16" piece of aluminum to fit the corners and to cover the hole by 1/2" on all sides. I sanded the area and wiped it down with acetone, then JB'd the whole thing. If this doesn't work, then I might use an expanding rubber plug. I'm afraid of what the heat might do to the head if I have it tig'd, given the thin wall thickness. I'll know by tomorrow!!
All is well with the repair. I have about 50 miles on it with no signs of leakage. While I had the opportunity, I replaced the thermostat (original!!), o-ring, tensioner bearing (got it at Grainger for $6.76), belt & coolant. My owner's manual says "if it has orange coolant, use the long-life stuff; if it has green coolant, use the regular stuff" (not verbatim). I asked my local dealer and they said the same thing. GAR! Being that my coolant was orangish-green, I flushed the whole thing and put in the green stuff. I'm keeping my fingers crossed!!
Originally Posted by texcan
How is your repair holding up? Interested in knowing!
Bear1911 - Is the sleeve to which you are referring a V10-specific item? Would one be able to get this right from Ford parts?
Brad
Originally Posted by rocketman442
So far, so good! I put around 300 miles on it with some heavy hauling and no leaks!! I went bananas preparing the surface, which I guess paid off. I have some pictures of it and I'll have them up here as soon as I remember how to do it! A while ago, I repaired a broken 442 emblem stud with JB Weld (then threaded it with the speed nut!) and have sworn by it ever since. It has a working temperature of 600 degrees F, so 200 degrees F is a walk in the park.
Brad
Brad
Here are the pics. Unfortunately, I took the picture of the actual hole with my phone.
http://img26.imageshack.us/img26/5316/dsc015443vn.jpg
http://img504.imageshack.us/img504/1544/dsc015461kq.jpg
http://img469.imageshack.us/img469/4538/dsc014091rg.jpg
http://img469.imageshack.us/img469/259/dsc013951hb.jpg
Images changed to links (it's a little nicer for the dial-up users. -Beast12
