Ford Exhaust leak!
Old 04-25-2002, 01:55 PM
76fordman's Avatar
76fordman
76fordman is offline
Ford Exhaust leak!
I have a 1976 F-150 Supercab with a 1973 400 motor. The other day it started making a ticking noise, so I got up under the pickup and it has an exhaust leak right where the exhaust pipe goes into the manifold. The bolts are extremely tight. Is there a gasket in there that prevents exhaust from leaking out or do I need to try and tighten it even more. Any help would be appreciated. Braxton
Old 04-25-2002, 02:31 PM
KJKozak2's Avatar
KJKozak2
KJKozak2 is offline
Ford Exhaust leak!
Sorry I can't answer that yet, but I'm going through this same thing on my 460. I replaced the exhaust manifold gasket and had to put new studs on the manifold. I torqued them to spec and it leaks like a sieve. I even tried to tighten it more to the point of almost bending the flange. No change.
The donut-like metal gasket on mine appears to be part of the manifold so I can't replace it. I plan to work on it tonight until it's fixed, so I can let you know in the morning what I find.
Hopefully some of the more learned folks here will have a solution before then.
Kevin K.
Old 04-25-2002, 04:23 PM
ford_nut's Avatar
ford_nut
ford_nut is offline
Ford Exhaust leak!
hi
there is a donut gasket that is sandwiched between the the manifold and the exhaust pipe. if that gasket blows out, you will get a nasty, annoying leak! if you can remove the 2 nuts off the studs and drop down the exhaust pipe, you should be able to replace that gasket. i believe that they are no more than $2.00 each! the trick however, is GETTING those nuts off! GOOD LUCK
Old 04-25-2002, 10:39 PM
7220driver's Avatar
7220driver
7220driver is offline
Ford Exhaust leak!
Somtimes the only way to loosen the nuts is to heat them with a torch to break the rust free. also,I've had good luck replacing steel nuts with brass, these will not corrode.
Old 04-25-2002, 11:27 PM
Vampiro's Avatar
Vampiro
Vampiro is offline
Ford Exhaust leak!
if you can't get the bolts out wouldt something like seal a gasket or a liquid gasket that gas or oil and stuff doesn't affect?
Old 04-26-2002, 12:28 AM
Unclej78's Avatar
Unclej78
Unclej78 is offline
Ford Exhaust leak!
HardScrabble
08-29-2011 10:10 PM
Tomm
1983 - 2012 Ranger & B-Series
01-28-2010 04:04 PM
masterson32
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
12-17-2009 01:45 PM
JW 4x4
Exhaust Systems
10-08-2003 10:28 AM
Lookinfurfun
09-13-2002 11:49 PM
Quick Reply: Ford Exhaust leak!
