Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
1995 Lightning Fog Lights
Old 10-20-2005, 11:31 PM
Jason Lewis's Avatar
Jason Lewis
Jason Lewis is offline
Wink 1995 Lightning Fog Lights
Hay i have a 1996 F150 with a 95 "Air Dam" i need a fog light kit for it. The oem ford parts as you wood figure is $187.00 each. I need a kit with lights and wiring harness and switch. In other words i need a whole kit. Any ideas?
Thanks Jason
Old 11-06-2005, 05:25 PM
run351's Avatar
run351
run351 is offline
I go to my local Nissan dealer, their older (pathfinder I think) used the same lense. The whole assembly is like $62.00
Old 11-07-2005, 12:58 PM
Jason Lewis
I ended up going to "Pep Boys" and geting a kit for $40.00 cam with every thing lights,wire,switch. I had to use "L Brackets" to hold the lights in the holes.
I will update my gallery soon.
Old 12-12-2005, 10:43 PM
max harris's Avatar
max harris
max harris is offline
Jason
I just pick up a air dam from parts train for one of my trucks. The question I have is when you installed your air dam did you have to drill any holes on the underside of the bumper. The one I got appears to have different holes than the regular stock air dam even though it is supposed to be for a Lightning. This air dam is going on a 96 extended cab Mark III conversion truck. Also what lights did you get from Pep Boys.
Thanks
Max
Old 12-12-2005, 11:12 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
The air dam is directly connected to the front bumper on the GEN 1 L's, so you will need to drill some holes to fasten it properly.
Old 12-13-2005, 01:16 AM
Jason Lewis
The body shop installed the air dam the fog light kit from pepboys is a "Rally" Kit Part#3104 almost a perfect fit looks dam good. I should have some picks up this weekend.
Old 12-13-2005, 01:52 PM
max harris's Avatar
max harris
Thanks
Thanks for the info on the air dam and lights. I figured that their would have to be some drilling involved for the air dam but had to ask. I'm leaving it black at this time. Love bug season down here in Florida will tear up the white paint bad. Only have to find a new rear bumper.
Max
rollin thunder
1999 to 2016 Super Duty
03-08-2019 11:16 AM
stv1991
13
03-01-2017 02:18 PM
cdmm151
2009 - 2014 F150
39
01-02-2013 09:26 AM
SuperDutyScaler
02-24-2012 08:54 AM
fiber_tek
06-06-2011 08:47 AM
Quick Reply: 1995 Lightning Fog Lights
