Bidiesel in PSD
Bidiesel in PSD
I have looked at 90% of the threads in this forum and I've been unable to discern a concensus.
It would be nice to know:
1. How many of you are using Biodiesel in a PSD?
2. Is your truck 6.0 or 7.3?
3. How long have you been running Biodiesel?
4. What mix are you running?
If you will reply to this post by question number I will tabulate the results on a weekly basis.
Let me be the first; #2,7.3 #3, 18 mo #4 B-100. FABMANDELUX.
I have a 2004 6.0.
have run every ratio from a B2 blend up to straight B100 from a pump and homemade.
never has an issue but i do change fuel filters @ every 10K miles as opposed to the usual 15K limit.
Runs quiter with more bio.
Power feels the same.
Am gonna make my own soon. My goal is to make a super high cetane formula at home.
Anybody with a PSD still under warranty worried about repairs not being covered? First, I'll say that my 99 7.3 cost me less than $1,000 out of pocket over 6 years, so I do believe in their reliability (that's $1,000 worth of Ford Quality Care parts and labor ). But I now have an 05 6.0 and my local Ford dealer told me that if I ran more than the recommended blend of 5% Biodiesel the warranty would not cover any repairs that might possibly be related to running Biodiesel. That included injectors, EGR valve, fuel pump, cat, on and on. Now I wouldn't take my truck in for repair and announce I was running B100. Could they tell? Anyone had to deal with that yet?
I've read posts claiming B100 is great for a PSD. Those of you who say so, are you diesel techs and offering an informed opinion? Like others, I'm trying to sift through the many comments that contradict each other and figure out whether it's safe to run B100 and not risk paying big bucks for repairs.
Valid concerns but your not gonna get the holy grail permission from Ford.
Face it, the big automakers are slow to embrace bio except for Cat and some of the other heavy equipment makers who actually extend your warranty if you use B100.
B5 is barely bio. Its a good start but if your nervous just keep paying the high prices of fuel until your out of warranty.
To answer your question Ford does routinely take a fuel sample when a big ticket warranty repair comes in.
Although i'm not a certified tech i do beleive i have an informed opionion as a diesel nut and bio user.
And i did stay at a Holiday Inn last night
Alot of guys give advice on Bio and have never used it.
The key with Bio is quality contol.
I wouldn't put some sketchy pump fuel or bio in my tank no matter what.
Some small gas stations could have algae in their fuel.
I once was near the mexical border in cali and the gas stations inline filters were so clogged that the diesel would barely flow out of the nozzle.
I had prepaid for $20.
I went inside and the guy said oh okay ,try another pump.
I declined and got my $$ back.
You see my point?
Bad fuel is available at alot of places.
So for you i would only try Bio in small amounts, lets say B20 from a known vendor or from your own brewing. I took a workshop class on how to do it and testing your product along the process is the best way to not have bad fuel.
Remember one thing.
Biodiesel tends to scrub carbon buildup out of your fuel system so its widely known to change your fuel filters after 1 or 2 tanks of running bio to rid the carbon crap out of your filters.
We have just started using bio in our trucks at work with mixed results. As for the psd, our 2000 7.3 is running as normal on b50, and all is good.
The 2005 had a tank of b75, which we could not even burn out. After the 4th filter plugged, we dropped the tank and drained it. We changed out filters (and oil while it was laid up), put the tank in and refilled with regular diesel, and it runs, but not good. Probably going to Ford to check injectors.
In my Pete, I've got 4000 miles on b50, and haven't had any trouble, filters or otherwise.
I've been running bio from my regular fuel supplier. I've had no problems even at the B20 level. But my only concern was with fords max B5 so I backed off to the B5 level. I have a farm and have 6 diesel engines some with over 7000 hrs. Even those engines ran better on the bio rather than the staright dino.
I think it has to do with the injectors and their design to pump diesel vs. biodiesel. I thought I saw a company in Washington that actually swaps out the new injectors for ones that are designed to handle bio also, in place of the factory injectors. As I stated in the past the studies I read were concerned with injector carbon deposits over B50 on the newer DI motors.
Along those same lines I did read online somewhere (i get lost) that Bosch stated officially that their injector pumps will not be affected by B100, and infact will honor any warrenty irregardless of the bio content.
Hey, I got to check out a clear diesel fuel at syntroleum at the port of catoosa, in oklahoma. I'm a crane operator and was working on a project there and they showed me what looked like a glass of water, but they said it was diesel. Then a few days after that I saw on the news them talking about it. Guess its supposed to burn real clean and have other positive properties.
