2.3l 4d55 diesel engine parts - any in the Atlantic?
Not Sure pnose. Is this similar to a pcv valve? The manual we have does not show a CDR. Where might it be located, top or bottom of the engine? We're not familiar with diesels at all (I am a gas mech!) - but I sure like this little 4X4. Thanks for the response. I spent 2 1/2 years in the mid 70's in your Province - Great place and Great People.
Frank
Frank
On my truck(1992,7.3)its located on the rear of the intake manifold and runs through a rubber grommet into the valley pan.Its about the size of a tuna can.As i stated i dont know how the mitsu is set up,however if your manual shows a pcv it could very well be what they are calling a cdr.There should be some device to control the base pressure.Hope this helps.I will check with some people and post what i find.
Thank You Sir. The manual says gas engines use a pcv vale and diesel's have a baffle in the valve cover!! Just a note - we just finished adjusting the valves and what a difference in power - time will tell wether or not the blow by will dissappear!! The manual stated that the valves should be adjusted every 15,000 miles. Didn't realize diesels needed frequent valve adj. - makes sense though. Will check for a tuna can contraption as well - lots of stuff on a diesel thats not on a gas!!!
Thanks for your help.
Frank
Frank
We took the hose that was going into the air filter out of the air filter and put it into a can and left it hanging to eliminate any oil being blown into the breather and sucked backed into the turbo, this eliminated the blue smoke out the exhaust. didn't see any baffle in the cover! Still learning, but it works alot better.
Thanks
Frank
Thanks
Frank
pnose - This Ranger was sitting for 3 to 4 years before we started playing with it. It only has 215,ooo klms on it. We've changed the oil and filter, adj. valves, changed fuel filters and water seperator, flushed rad, new belts, adj. timming and new belt and more repairs to the truck. Is there anything else we could do for the engine?
You should always run a fuel additive,available at ctc,wallmart,etc.It will provide lubrication for the fuel system components as todays diesel lacks the sulpher needed for lubrication of these parts.It will also aid in preventing the fuel from gelling in extreme cold.I add about 1/2 cup every fill,all year round.The hose you removed from the breather,where does the other end go?
Originally Posted by ovcshop
Will check it, but it is on the intake manifold? I think we didn't tighten up the Harmonic balancer enough when we adjusted the timeing - it came loose and is now no good!! Not too smart! Now we are haveing a hard time finding another.
The canister on the intake valve looks like a vent affair. There isn't anything going in or comming out of it! It's just plumed into the intake?? We will take it off and have alook anyway. Found a HB - purchased and on it's way, From AutoZone.com, an auto parts store in the USA which comes in awlfull handy sometimes. Thanks for your help Sir.
