Code P1212 Cause
I have been using Rotella 15W-40 oil. Have also been using Lucus oil additive. Told by Ryan Bean @ Bean's Diesel Products, referral of Black Cloud Diesel (this is where I had injectors rebuilt) that this additive was not good for the truck. He has recommended Schaeffer's Oils and Specialized Lubicants. I will be changing my oil today.(Looks like the oil is thick). I have plenty of the Rotella 15W-40 on hand for this, as well as a new oil filter. Do you think this will clear the P1212 code, or do you think the sensor is going bad?I have pulled sensor and check high oil pressure pump, it is full.
Just wanted you to know I did some backtracking to find out about the P1212 code. It seems that when I had the 3 injectors rebuilt @ Beans Diesel that they had also gotten this code. They had forgotten to clear it before I came home. As it was explained to me, when they rebuilt the injectors,it is a standard code that comes up whenever the injectors are changed out, and the oil is drained out of the lines,then work on the injectors is done.The oil line is refilled in the lines and rail, causing this code. I did my regular oil change and used my scanner to clear the code. Truck runs great!
tidexp
23
09-09-2012 08:37 PM
B-Ryan 02
12-31-2009 08:04 AM
