Biodiesel MPG
Old 10-07-2005, 05:19 PM
onioncasserole's Avatar
onioncasserole
onioncasserole is offline
Biodiesel MPG
What kind of MPG do you get with your vehicle compared to when it was petro-Diesel?
Old 10-07-2005, 08:03 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
I'm using premium fuel with 5% biodiesel from soybeans and it added about 1 to 2 mpg but it helped a lot with the smell and the noise from the engine. It added in this combo about .04 per gallon (2 for premium and 2 for the soy)
Old 10-08-2005, 05:11 PM
Fish370ec's Avatar
Fish370ec
Fish370ec is offline
Mileage
I picked up my new 06 6.0 350 a little over a week ago and just got back from a 700 mile trip. The truck already had a "few" miles on it do to being a dealer trade. In any event, I got 19mph for the trip. Averaged about 70. I have to say, that I was thrilled (understatement). Anyway, the local Meijer sells Bio, but only B20 so I need to "water" it down with petro diesel to get to a 5% ratio (according to the manual, no more then 5% should be used). In any event, if I can add even 1 mile per gallon by using Bio, then I am totally in. Better mileage and less reliance on the Middle East.
Fish.
Old 10-09-2005, 03:59 PM
onioncasserole
Does using 100% biodiesel get worse MPG compared to using 100% petro-diesel?
Old 10-09-2005, 07:04 PM
kregars's Avatar
kregars
kregars is offline
From my understanding, using straight 100 (B100) will generally give you about the same results as #2 pump. However..if you are brewing your own, which is what I think your getting at, you may find that the milage clock is less often monitored but be sure to have a spare filter as B5-B100 will clean out the entire fuel delivery system and clog the filter...just depends on what ratio you go with etc.
Also from my understanding, buying straight 100 (or even B99) is somewhat cost prohibitive. YMMV (literally)
Old 10-10-2005, 01:30 AM
Sportdeck262's Avatar
Sportdeck262
Sportdeck262 is offline
Virgin B100 from a fuel supplier used to be more expensive than dino-diesel. Since the $ runnup after Katrina and Rita, the price of BD has not gone up as much. I bought B100 for $2.75/gal (including all road tax) last week from a distributor in Metro Atl. The local price for dino-diesel is $3.09-$3.49 depending on the location. Check with local fuel distributors if you want to purchase direct. It may be a pleasant suprise.
Old 10-10-2005, 11:08 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Talking
I use B-100 in 4 rigs, Lowest gain 1.6 mpg. Best gain 3.8. Also noticed 10 percent gain in irrigation pumps of gallons per hour pumped at same rpm as dinodiesel. All engines seem to run quieter. I'll never go back to dinodiesel!!! FABMANDELUX.
Old 10-10-2005, 12:58 PM
Fish370ec's Avatar
Fish370ec
Is there a reason why Ford only recommends B5? It seems that some/many are running B20 or even B100. Are these being run in 6.0s or 7.3s or something completely different?
Fish
Old 10-10-2005, 07:28 PM
bigredtruckmi
According to International Truck--- TSI -05 -12 -21 May 2005 International will warranty engines up to B5 or 5% biodiesel if the fuel meets ASTM D975 fuel quality standards. B20 does not meet these specifications. But there is work being done within the ASTM for a B20 specification.
Old 10-11-2005, 04:22 PM
Fish370ec's Avatar
Fish370ec
Cool, thanks - I will try the B5 and then when and if the B20 is approved for ASTM and International and Ford recognize it, then I will switch to that as it appears alot of people are having good luck with it.
Old 10-11-2005, 07:44 PM
bigredtruckmi
I was using the B20 until we got the 04 and found out about the warranty issue. I have 4 diesels for the farm ( tractors etc) and 2 diesel pickups. so we go thru a lot of fuel in the spring and fall. I had no problems but the older equipment quit smoking and ran smoother than on #2.
elemint
2015 - 2020 F150
02-25-2014 02:09 PM
Dogmann
Modular V10 (6.8l)
10-03-2013 08:37 AM
xjvince
08-17-2006 11:01 PM
bsprowl
08-28-2001 07:02 PM
Avanti
02-12-2001 01:57 PM
Quick Reply: Biodiesel MPG
