looking to purchase a '92 F-350 diesel
Old 10-05-2005, 06:26 PM
665Paul's Avatar
665Paul
665Paul is offline
Question looking to buy and convert a '92 F-350 diesel to SVO
hello, I'm interested in buying a '92 F-350 to run on either svo or wvo or even biodiesel. I'm reading alot about how to make the biodiesel and to use vo as a strait fuel. Are there problems with converting the 350 or are the conversions of injectors, glow plugs, fuel heaters and the such really requiered for the 350 to operate properly? I know that it has dual fuel tanks so doing a start/stop on petro-diesel would not be a problem.
Old 10-06-2005, 07:11 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 03-01-2006, 03:27 AM
Spincycled's Avatar
Spincycled
Spincycled is offline
Ive heard its best to have a heater for the fuel tanks and even a temperature gauge to keep it around 130 degrees . It will prevent the WVO from becoming thick and or hardening and clogging up your injectors, etc. Also make sure you properly filter the WVO and take steps to remove any water. Im thinking of putting my flatbed on my f150 and maybee even the engine etc later on if thats even possible. If anyone knows please help with any input..
Old 03-01-2006, 05:55 PM
cookie88's Avatar
cookie88
cookie88 is offline
Welcome to FTE 665Paul and Spincycled.
Old 03-02-2006, 04:30 AM
leskwvo's Avatar
leskwvo
leskwvo is offline
Yes to run straight WVO/SVO you need heat. Coolant heat is the easiest to get and use. From Heat exchangers, Hose on hose (HOH), Hose in Hose (HIH), and heated fuel pickups you can get all the heat you need in most parts of the country. If you live in Minnesota you may need to add electric heat. Your target is 160F or more for the best performance of WVO/SVO.
The pre-PSD Fords are simple to convert and hold up well. Take a look at the article over in the article section on this forum Can a Diesel run on Veggie Oil
Welcome
tndiesel
06-18-2008 04:44 PM
kevbits
Bio-diesel, Propane & Alternative Diesel Engine Fuels
11-30-2007 04:13 PM
PSNut
41
08-17-2006 10:41 AM
onioncasserole
03-08-2005 09:55 AM
F150Canuck
16
02-23-2004 07:17 AM
Quick Reply: looking to purchase a '92 F-350 diesel
