96 f-250 7.3 di. psd running on wvo & diesel mix
Old 09-27-2005, 12:01 PM
funzjb1's Avatar
funzjb1
funzjb1 is offline
Thumbs up 96 f-250 7.3 di. psd running on wvo & diesel mix
Just wanted you guys to know I am running on a mix of 20% diesel and 80% wvo ( waste veggie oil) about 1000 miles down already still going great. It is pretty cheep fuel. I also wanted to know if anyone else is doing this and how you get areound the fuel filter problem ( will clog alot sooner due to veggie oil and paper do not do well together) I carry spare under hood for emergencies. I see NO power loss or any differnce in running. I have heard if you run without filter in original area it runs poorly????? Has anyone heard of a stainless steel filter for PSD ???? to use as original equipment. I am getting 105 mpg of diesel (mixed with wvo).
96 F-250 D.I. PSD, 8" lift, 38" tires (3.55 gears),edge super chip, homemade air flow system, 3" down pipe, 4" exhaust ( 161,000 miles)
Old 09-27-2005, 12:11 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
I do this on the '96 works great I was only getting like 30 mpg of #2 sometimes 40 MPG but I have 4:10's
the stock filter lasted me 4K before it finaly gooed up enough that I noticed a difference on the pyro and boost, both were lower.
Never heard of a stainless filter for a PSD that would fit in the original canister.
Diesel Rod
Old 09-27-2005, 01:11 PM
Barnacle Bill's Avatar
Barnacle Bill
Barnacle Bill is offline
I am making the switch also. But I had not heard about stock filter gooing up at 4000 mi.
I recently replaced the fuel filter so it is not the original. What brand/type of filter element should I use?
Old 09-27-2005, 01:20 PM
funzjb1's Avatar
funzjb1
funzjb1 is offline
I have heard of variations with different filters( inline ones) using steel wool pads for filters or using 200 count stainless mesh. I think I will have to invent one.
Old 09-27-2005, 01:36 PM
444dieselrod
"most" do a full convertion and the WVO never sees the stock filter, I plan on using a racor filter with a seperate mounting base on the firewall somewhere, for the WVO and then the WVO/#2 mix will never be in the stock filter housing, just haven't got that far yet.
Diesel Rod
Old 09-27-2005, 10:01 PM
cookie88's Avatar
cookie88
cookie88 is offline
I love these threads....makes me think I might want to take a crack at making my own someday.
Thread moved to proper forum.
JRogersOU
08-16-2014 11:00 PM
onthemoveactivist
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-13-2014 12:42 AM
444dieselrod
01-25-2013 03:23 PM
VaFordman26
01-11-2013 08:14 AM
linus72
07-11-2012 07:14 AM
Quick Reply: 96 f-250 7.3 di. psd running on wvo & diesel mix
