motor mounts 302/351w same?
Old 09-20-2005, 09:53 PM
FordCrazy1970's Avatar
FordCrazy1970
FordCrazy1970 is offline
Smile motor mounts 302/351w same?
Is there a differance in motor mount location and type of motor mount you would on a 302 verses 351w? Installing a 302 and replacing a 351w I know alot of parts interchange but do they use the same motor mounts in the same location?
Old 09-20-2005, 11:13 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,680 Likes on 1,357 Posts
Yes, the same motor mount holes in the block.
Old 09-21-2005, 03:26 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
so your taking the 302 out for a 351w?
yes the mounts are identical
Old 09-21-2005, 06:36 PM
FordCrazy1970
thanks! Do they bolt to the same location on the crossmember bracket?
Old 09-21-2005, 06:42 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
Yes, there's no difference. A 351W will bolt straight in where a 302 came out of. About the only problem you might encounter would be on the exhaust sytem. The 351W Has about an inch more deck height which will raise your manifolds or headers a little higher in the chassis, and further apart. Usually there is enough play in the exhaust sytem to adjust for the difference.
Austin Climer
02-22-2017 10:17 AM
NCTyphoonKid
08-11-2016 07:53 PM
jtjohn302
03-01-2013 09:39 PM
cbr3
02-14-2012 06:19 PM
Bender99
01-22-2010 06:06 AM
Quick Reply: motor mounts 302/351w same?
