EGR insufficient flow code showing
Old 11-05-2005, 07:22 AM
FS-150's Avatar
FS-150
FS-150 is offline
Originally Posted by jdwheels
DPFE sensor? I am slow, what is that?
DPFE = Differential Pressure Feedback Exhaust (sensor)
Old 11-05-2005, 03:03 PM
Blue Bonnet's Avatar
Blue Bonnet
Blue Bonnet is offline
if the code is p0401 replace the dpfe sensor
Old 11-07-2005, 08:00 AM
davenpt's Avatar
davenpt
davenpt is offline
thanks for all the info, guys ( or gals). i did end up changing the EGR valve and the sensor, and the light still came back on. i will try the suggestions in order of simplicity, and see what happens. i still only have 33K miles on the truck. seems to run fine. so i don't know if whatever is causing the light to be on, is hurting anything or not. does anyone know if it might be bad to drive while the light is on?
thanks again for taking time everyone...
dave
Old 11-07-2005, 08:04 AM
chrisindallas's Avatar
chrisindallas
chrisindallas is offline
I still say try the fuel filter.. around 15 bucks and easy to change.. I changed my DPFE and also cleaned the ports and finially replaced the egr valve.. No luck.. Then somewhere on here someone suggested the fuel filter. IT WORKED! Just remember to use the fuel cutoff switch or else you will get a mouthfull of gas... (around 10 bucks in gas) lol
Old 11-07-2005, 08:14 AM
FS-150's Avatar
FS-150
FS-150 is offline
Don't forget, you also need a special tool to release the fuel line connectors. If you don't have one already, any auto parts store should have one.
Old 11-07-2005, 09:35 AM
Blue Bonnet
you need someone to clear the codes form the pcm so the light will go out.it will not clear by itself. sometimes disconnecting the battery will work but not always.its not dangerous to drive around with the check engine light on but if something else happens with your emissions system you will not know there is something wrong because the light is still on. so have someone clear it and shut the light out.
Old 07-07-2014, 01:33 PM
guitar_199's Avatar
guitar_199
guitar_199 is offline
I know I am waking up a really old one here.....
But can someone tell me how a fuel filter can cause a P0401?
Towzilla
07-24-2021 11:12 AM
Al_Cuevas
1997 - 2003 F150
93
08-13-2016 08:50 AM
aeford66
12-08-2015 12:25 AM
jreze8
1999 to 2016 Super Duty
04-05-2011 10:26 AM
roller_steve
08-02-2008 11:35 PM
Quick Reply: EGR insufficient flow code showing
