Soy BioDiesel
Old 09-15-2005, 03:04 PM
redwingsfan's Avatar
redwingsfan
redwingsfan is offline
Soy BioDiesel
Anybody tried Soy BioDiesel in the PSD? I am just starting to research and wanted to know if it is worth it, or if it can even be used in a PSD.
Old 09-15-2005, 03:13 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
Pump it in and drive. It's no different than petro-d other than the oil source. Well, it's better in many ways.....
Old 09-17-2005, 05:02 PM
MDB's Avatar
MDB
MDB is offline
Am I correct in thinking that you don't want to run more then about B20 in anything older then 1999? Seems to me I read this somewhere, and has something to do with the o-rings being made of a different compound.
Old 09-17-2005, 05:17 PM
scole250's Avatar
scole250
scole250 is offline
The methanol used to make bio-diesel has a solvent effect on some plastic and rubber parts and over time will break them down. Not all rubber/plastic parts are affected. It depends what it's made of, can't remember the name of the materials. Newer engines are supposed to have more of the non-affected rubber/plastic material in them, but I've not read anywhere what years, if any of the Power Strokes use the "safe" material.
Old 09-17-2005, 10:37 PM
bczolone's Avatar
bczolone
bczolone is offline
I have been making my own now for about 2 months all in small batches. I have not put any in my 2004 PSD becaus of unreliable information as to the side effects. I have read as much as I can off the internet including the University of Missouri and Idaho projects including several others. I have made it using several types of oil that is waste. I even made a batch from bacon grease. Right now I'am using used soy oil that was in the fryers for 6 weeks...it really bad but my end products are all crystal clear and aside from smell and viscosity look just like DF #2 in appearence. Ran about ten gallons so far in tractor and pressure washer...no problems. From one report they suggest not using it straight in any direct inject or commonrail systems because of excessive carbon deposits on the injectors. IDI diesel are perfect for 100% Biodiesel; ie. 1994 or older Fords. Not sure on the dodge. They recommend 1985 or older Mercedes as the best all round. Anyways there is tone of info and recipes...im trying a new one now using a first stage with SO4...14 molar or 95% so we'll see how it turns out. The methanol is not the culprit in destroying rubber fuel lines, its the oil itself. Most all vehicles '96 or newer use Viton hoses which are not affected so therefore you would be wise to replace any rubber fuel lines with Viton.
Old 09-19-2005, 12:10 AM
dhag911's Avatar
dhag911
dhag911 is offline
couldn't dilute the soy diesel you are making with pump pertro diesel?
where could you find recipes to make your own fuel?
Old 09-19-2005, 03:03 PM
bczolone's Avatar
bczolone
bczolone is offline
Recipe
I am using severl incl. the one from Utah Biodiesel and Journey to Forever website...look up biodiesel there's more than you can read in a week...anyways my above post I wrote while really tired...its deer season here in California, but I tried a new recipe using Sulfuric Acid (not SO4) I meant H2SO4, but it didn't turn out to great...I'll have to review it to see what I did wrong. I'm currently doing one right now. The used vegable oil I use is soy oil from a restaurant locally.
Gun-Driver
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-31-2007 08:31 PM
joe_buzz
05-13-2006 03:21 AM
AndysFords
04-14-2006 10:47 PM
78fordman
23
02-29-2004 09:55 PM
soy4soy
Bronco II
04-05-2003 04:57 PM
Quick Reply: Soy BioDiesel
