AOD/AODE difference/identification
Old 09-09-2005, 03:52 PM
gov2mod's Avatar
gov2mod
gov2mod is offline
What the easiest way to tell the difference between an AOD and an AODE transmission? I know that when it's in the truck the AODE has a push button overdrive but what if the transmission is out? I usually identify by the pan but both AOD/AODE have similar pans. I need two AOD's, one for my 90 Bronco and one for my 90 F150. Can you put an AODE in place of an AOD without much trouble? Is the AODE controlled by the computer like the E4OD or does it just have an electric overdrive. Or, should I just continue to look for an AOD only?
Old 09-09-2005, 04:33 PM
l-m tech's Avatar
l-m tech
l-m tech is offline
the aod uses a cable to adjust line pressure.the aode has a electical connection the right hand side of the trans that controls the epc pressure ,torque converter and shift solinoids.
Old 09-09-2005, 05:01 PM
gov2mod's Avatar
gov2mod
gov2mod is offline
Thanks. I knew about the TV cable on the AOD's but I'm not familiar with the AODE. I wasn't sure if the AODE used the cable and electrical connection or just electrical. I assume then that the AODE uses the computer to control it when the AOD doesn't.
Old 09-09-2005, 05:15 PM
subford's Avatar
subford
subford is offline
Yes, that is true and I think the bell housing is a little longer on the AODE it also has a lot more plugs.
Old 09-10-2005, 11:06 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
Old 06-28-2011, 01:50 PM
randyws's Avatar
randyws
randyws is offline
e4od has the button on the shifter, not the aode.
Old 06-28-2011, 02:30 PM
gov2mod's Avatar
gov2mod
gov2mod is offline
I'm pretty sure my 91 and 93 Bronco's have the E4OD transmissions while my 90 has a (still need one) AOD. But my 93 has the button on the end of the shifter while my 91 has the button on the dash.
Old 06-28-2011, 06:28 PM
randyws's Avatar
randyws
randyws is offline
Right, e4od has the button, aod doesn't (it isn't electronic ), aode is electronic (without a button).
Old 06-28-2011, 06:41 PM
subford's Avatar
subford
subford is offline
The AODE was only put in cars anyway.
Old 06-28-2011, 11:30 PM
85e150's Avatar
85e150
6 years ago this was a question......
Old 06-29-2011, 02:23 AM
randyws's Avatar
randyws
randyws is offline
Actually, starting in 1991 it went in the f-series pick-ups.
Old 06-29-2011, 02:24 AM
randyws's Avatar
randyws
randyws is offline
And, yes this is old.
Old 06-29-2011, 07:51 AM
subford's Avatar
subford
subford is offline
What went in f-series pick-ups in 1991?
The AODE did not. It was only put in cars and never in trucks.
The 4R70W (AODE-W) was put in trucks but 1993 was the first year for it and it had the Transmission Control Switch (TCS) on the end of the gear selector lever.
The AODE and the 4R70W (AODE-W) are not the same transmission.
They have different gear ratios, output shaft sizes to name two differences but their were other differences also.
Old 06-29-2011, 09:26 AM
randyws's Avatar
randyws
randyws is offline
Oh, one of those.
ralphhood3
12-03-2014 04:46 PM
bjmayberry2
34
04-09-2014 03:13 PM
andyman91
01-29-2014 11:05 AM
mantta
04-26-2001 03:31 PM
Quick Reply: AOD/AODE difference/identification
