Iowa Chapter Join Chapter, Leader:
Anybody know where I can find 8 bolt front hubs?
Old 09-02-2005, 01:42 PM
concretegarage's Avatar
concretegarage
concretegarage is offline
Its for my '55 F350. I'm replacing the rear axle with a Dana 70 and would like to keep the bolt pattern the same. I've heard that some of the 250's had 8 bolt wheel patterns, and was hoping to locate some hubs that I could put on the front of my truck.
Old 09-02-2005, 03:01 PM
fordloverf2501970's Avatar
fordloverf2501970
fordloverf2501970 is offline
i am sure dougs would have some down in pella, but dont know what he sells them for
Old 09-02-2005, 03:03 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
I don't know for sure what spindles you have or if you have converted them to disk brakes but almost every junkyard in the state should have F250s around, and yes they would be 8 bolt hubs or a better bet would be to look for an E350 cube van like the D70 most likely came out of.
Old 09-02-2005, 07:39 PM
fellro86's Avatar
fellro86
fellro86 is offline
I've got a front stub that has the hubs on it. I would have to go look to be absolutely certain, but I do believe I have them. All 250's have 8 bolts at least after the 60's. Trick is that you have a straight axle, and these are twin I beam.. I know that a 64 would have a straight axle with the 8 bolt hubs.
Old 09-03-2005, 07:22 AM
69 and 85's Avatar
69 and 85
69 and 85 is offline
Do you already have the Dana 70? I have one as well as the fronts, but again.... twin I-beam from an F350.
