Coil Failure
Old 08-31-2005, 12:55 PM
FarmTruk's Avatar
FarmTruk
FarmTruk is offline
Coil Failure
I have inherited a farm truck that is burning out coils, 4 so far. The engine is a 534 cid from a bluebird motorhome. The truck is a dual axle, cab over f series.
I do not know if this engine was supposed to have a resistance wire or not. Or if the coil was supposed to have a built in resistor? Any idea's?
Blowing a coil in this truck is really bad news, as the air system will loose pressure and lock the brakes.
Thanks
Old 08-31-2005, 04:18 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 08-31-2005, 07:21 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
well turn the ignition on take a voltage tester and test the voltage at the coil it should be 9 volts or so. you can also add a aftermarket one to that uses 12v the accel does and was 29.00 and has been great.
Old 09-01-2005, 10:45 AM
FarmTruk's Avatar
FarmTruk
FarmTruk is offline
Question
Ok, I have verified the voltage to the coil is correct.
Any other reason to be burning out coils? Bad wire to the distributor? Cracked distributor cap? Point/Condenser problem? Loose wires to the +/- coil terminals? Anything?
Thanks for your help!
Maltman
09-12-2013 12:24 PM
Rick_Fury
06-18-2012 03:32 PM
Torb968
Modular V8 (4.6L, 5.4L)
30
07-01-2009 03:24 PM
Spudco
02-28-2004 01:47 PM
Torb968
1997 - 2003 F150
01-29-2004 11:46 AM
Quick Reply: Coil Failure
