1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
98 Ranger Fuse Box Diagram
Old 08-30-2005, 08:54 PM
Kleppe's Avatar
Kleppe
Kleppe is offline
I was wondering if anyone could help me out by knowing where a Fuse Box Diagram of my 98' Ford Ranger is. I think i may of blown a fuse for my Cigerrette lighter and 12V Plug-in. They both don't work, and i checked the wiring behind them to make sure they were plugged in. I just installed a new CD Player, and it sparked one time when i was installing it and im wondering if that didn't blow it. Anyone else have any idea's on why my cigerrette lighter and that 12V plug don't work?
Old 08-30-2005, 08:57 PM
Ken00's Avatar
Ken00
Ken00 is offline
Welcome to FTE!!!!
The diagram should be in the owners manual, if you don't have one try this link.
If you saw a spark I bet you blew a fuse.
Old 08-30-2005, 09:21 PM
Kleppe's Avatar
Kleppe
Kleppe is offline
Hey thanks for the quick reply. I did find the guide in their. Now i just need to go buy the fuse's. I hope that does it! I think im just going to replace all the fuses to make sure they all are working good.
Old 08-31-2005, 07:44 PM
Ken00's Avatar
Ken00
Ken00 is offline
It's easy to test a fuse with a VOM meter.
Old 08-31-2005, 08:16 PM
GeneB_45's Avatar
GeneB_45
GeneB_45 is offline
I wouldn't change the fuses just be on the safe side.
It seems apparent you blew the fuse for a reason, NOT just old age.
You can also check the fuses with a test light without removing the fuses.
Put the alligator clip on a known good ground, and touch both sides of "shiny metal"
on the tops of each fuse.
Your test light will light, if the fuse isn't blown.
/Gene
Old 09-05-2005, 03:19 AM
mech63b's Avatar
mech63b
mech63b is offline
Hey I had the same problem after I installed my pioneer. Keep in mind that there is also a fuse for the radio in the fuse box under the hood on the drivers side of the truck. My suggestion is before you replace any fuses make sure you pull the cd player and check that all the wires are hooked up correctly and either have soderless connectors on them or electrical tape so that none of them can ground out and blow another fuse. I hope this helps
Old 11-05-2005, 03:01 PM
Old Tbone's Avatar
Old Tbone
Old Tbone is offline
OK, found the Owners Manual via the link posted by KEN00...thanks mucho....that was immensely helpful. Found out there was no fuse in the slot, put one in, and sure 'nuff the dome light wouldn't go out! WD-40 did the trick, and now I'm in business. Didn't have to fool with that crazy dome light cover after all!!!
Thanks for your help,
Tom
Old 11-05-2005, 05:54 PM
Ken00's Avatar
Ken00
Ken00 is offline
Glad to hear you got things fixed!!
thegrit
1999 to 2016 Super Duty
03-21-2015 06:01 AM
Rags1996
03-10-2015 12:05 PM
FORD E-150
1997 - 2003 F150
02-28-2015 07:43 AM
919rider
01-03-2013 02:06 AM
dino360
02-20-2011 08:23 PM
Quick Reply: 98 Ranger Fuse Box Diagram
