I want to run my 302 off ethanol
Old 08-28-2005, 08:05 PM
Huntersbo's Avatar
Huntersbo
Huntersbo is offline
anybody know what the price is of ethanol per gallon?
I will run a holley carb and re jet it, and probably run a fuel heater.
What compresstion ratio can I run with a 194 duturation cam on pure ethanol and iron heads? With that compression what do I have to limit my valve lift to?
any body know where I can buy Ethanol in the san diego area?
thanks
Old 08-29-2005, 08:40 PM
fellro86's Avatar
fellro86
fellro86 is offline
Straight ethanol is not very redily available, but E85 is. It is 85% ethanol, 15% gasoline. This mix is 105 octane, so you can bump up the compression a bit, but fuel availability is the problem. California isn't exactly ethanol friendly, so I can't say if you will find it, but www.e85fuel.org has most of the locations listed on their maps.
Old 08-29-2005, 10:35 PM
Huntersbo's Avatar
Huntersbo
thanks alot
Old 08-30-2005, 10:13 AM
fellro86's Avatar
fellro86
fellro86 is offline
Oops, that address is wrong, you need www.e85fuel.com, not org. It appears there is ONE station in California, San Diego. Location
coley909
6.2L V8
06-05-2016 11:00 PM
RedTaurus94
20
06-10-2014 04:39 PM
returningphoenix
31
04-09-2014 10:03 PM
Dean88
Alternative Fuels, Hybrids & Mileage
07-23-2007 02:35 PM
wickymustang
10-27-2005 10:38 AM
Quick Reply: I want to run my 302 off ethanol
